Question about Motorola Mobility RAZR V3
Pls help with template problem
I have a motoloa razr and im stuck sending text messages in multimedia format, how do i change it back to txt format?? i really appreciate it...
  • Tony Stark Nov 05, 2007
    i have a motoloa razr and im stuck sending text messages in multimedia format, how do i change it back to txt format?? i really appreciate it...
    Guru:
  • 155 Answers
When you go "new message" in the messages menu it should give you an option of text message as well as multimedia message and other things. If the problem is when replying to messages it should automatically send in text format and if it doesn't then it should once you have sent some "text" messages from the "new message" option. Hope this helps :-)
Posted on Nov 06, 2007
SOURCE:
How to add signature on text messages
There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
Message templates
When you often use the same phrases, you can save the message under template messages. Adding the message as a template
  1. Press Menu > Messaging > Templates.
  2. Press Options > Add New.
  3. Write the frequently used message > Options > Save.
Sending a message with template
  2. Select the message to send.
  3. Edit the message > Options > Send.
note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
Mar 08, 2011 | Pantech Cell Phones
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
Can't send a Text Msg on my Razor
go to create message then select the format:
New Short Message
New MMS Message
MMS Templates
Send to online album.
Start with the first option,then you do a little more exploring with the different formats.
Mar 03, 2009 | Motorola Mobility RAZR V3
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
Help!
Your phone ran out of memory and the only way the messages could be sent or received is through mms on the phone. You need to clear out the in and out box often so the phone will not do this. Also you must reboot the phone after you have cleared out the in and out box. Then it should work.
Feb 09, 2008 | Motorola Mobility RAZR V3
Motorola razr v3xx - automatically sending text messages in the multimedia/picture format
Hmmmm, a good one. I need to ask first, who is your service provider? I can walk you thru it after i know who your with.
Dec 14, 2007 | Motorola Mobility RAZR V3
Regular texts change to picture msgs when sending!
just happened to me. deleted my inbox(400+ messages) and it went back to normal.
Dec 03, 2007 | Motorola Mobility RAZR V3
Text Messaging randomly turns into Multimedia Messaging
I had the exact same problem and it did help when I deleted all my received texts. I started having the problem when I had more than 400 text messages stored in my phone.
Nov 15, 2007 | Motorola Mobility RAZR V3
RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
Nov 07, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
MMS is default for messages
I had this problem develop for my Razr V3xx, but after emptying out all my messages in my inbox, outbox, and drafts, it returned to a normal text message format. Hope it works for you as well.
Oct 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
