Question about Brother MFC-290C Printer
Paper jam on a brother MFC-290C
The paper has been cleared, but it will not recycle. it will start again with a sound of gears not meshing then a sound of the printer printing and after a few seconds there is the same sound of the gears clicking and not advancing the paper. all the paper has been cleared, but the printer still shows a paper jam. any and all help in resolving this problem would be greatly appreciated
    President:
  • 2,306 Answers
Sounds like there is still paper in there, carefully move the carriage assembly to the left and look in with a flashlight, also check the left side with the light. Usually paper gets wrinkled and shoved to one side or the other.
Posted on Jun 26, 2009
  • Dave Soper
    Dave Soper Apr 26, 2015
    no paper anywhere at all still shows doccument jam scanner
Keeps saying there is a paper jam and there is no paper jam what so ever
Still the logic board thinks there must be a paper jam. Could be caused by a defective sensor, bad connection from sensor to logic board or a defective logic board. And what is very common, something dropped in the printer and really blocks a sensor.
check all places where the paper can go, if perhaps a paperclip or a little scrap od paper is blocking a sensor.
Or contact a service centre, or perhaps you start sving for a new printer?
Apr 26, 2015 | Brother MFC-290C Printer
Brother MFC-290C error 35 how to fix it? and what is error 35
The machine does not work due to a paper jam.
For troubleshooting paper jams on that specific model go here
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000400/000095/faq000495_033.html?reg=us&c=us_ot&lang=en&prod=mfc290c_all&Cat=11
Mar 01, 2011 | Office Equipment & Supplies
When i print my printer slow paper jam please tell me about to clear it
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.Hope this helps you.
Thanks
Michel
Jan 31, 2011 | Brother MFC-290C Printer
My printer Brother DCP 145C doesn't want to print. It takes the paper and then stops. It displays message: Print Unable 36.
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 07, 2010 | Office Equipment & Supplies
My printer is asking me to refer to troubleshooting and the routine maintanence chapter in users manuel for - print unable 36 Does anyone know how I go about fixing this? Nikki
Sep 02, 2010 | Brother Office Equipment & Supplies
I have a paper jam...how do i clear the paper jam?
I would always just look for the paper to get out. Some printers lift up to the area where the paper slides througha nd you can pull it out just like that. Then, before printing again... just make sure your paper is lined up just right. You might be able to look in the intake spot for paper and see some of the paper hanging out from there.
Jul 07, 2009 | Brother MFC-290C Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Paper Jam - now terribly noisy!
Fuser gear cracked from the sound of it or non oem or recycled toner cart that is too stiff to turn correctly
Dec 12, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-290C Printer Logo
460 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
