Question about Acer Aspire L100 PC Desktop
My motheboard has overheated! I would like to get it running again but am mindfull that a new board will present its own challenegs. What component needs to be repaired?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hi..1st replace the capacitors 2nd check the ATX power Supply then 3rd check all diodes on board..good luck
Posted on Jun 26, 2009
Blowing but no heat
The problem needs to be identified as it could be one of 4 problems.
The Thermal fuse needs to be checked firstly as this prevents overheating of the dryer.
If it is OK check the continuity of the heating element with an Ohm meter, check also whether there is a reading present, meaning it should not read zero Ohms.
Components that do not commonly cause this problem are the High Limit Thermostat and the Main Control Board.
If the first 2 checks are fine, check the thermostat to see whether it is "open" (Not giving a reading on an Ohm meter) if so, replace.
The main control board very seldomly causes this problem but it does not rule it out.
Mar 28, 2014 | LG DLE2532W Electric Dryer
Tripping GFI
proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 17, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Ive got a d90d25eslr111-b1 micro combi,i poached an egg ani ie exploded in the micro,it blew the electic and went off,if i swith it on its ok,as soon as i shut the door it fuses the electric. why plea
see this causes and fix it. God bless you
Sep 27, 2012 | Morphy Richards Microwave Ovens
Our Schneider Altiver 71 drive power board was damage. Can we repair that part?
Eh, The power board is modular in design and as such is easily replaceable. Repairing the failed component, may get it running again, but it is hard to tell whether the life of the other components have been compromised. Check you warranty coverage. In the least, if you buy a replacement, you should be able to get a warranty with it, in case issues arise again. Try to determine if the failure was due to incorrect voltage or overheating. Your unit is equiped with thermal protection. See if perhaps that protection failed and caused the damage to the power module.
Good Luck!
Jun 20, 2011 | Garden
Abit kn9 sli overheating ??
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
Aug 01, 2009 | Abit KN9-SLI Motherboard
Sylvania ipod..batter charging
I called the company tech line..after some discussion it was determined that I must have a defective unit and I will return it to Walgreens.
Thank you
Deb
Jan 08, 2009 | Audio Players & Recorders
About intel 865 motherboard
i have intel 865 motheboard but it's restart or hang after one hour & when it restart automatically getting display problem please help me
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Fisher paykel washing machine top loader model aw0850 fresh5
On the morning of Monday 23/6/08, I have decided to measure the effected components on the control (power) board.
The control or power board is the one that supply the DC power to the DC motor which runs the tumbler of the machine.
I could see black marks around 3 leg component which is clamped against the cooling pipe on the board.
I decided to enter the component number the one printed on it in the internet Go ogle site.
The description of the 3 leg component was TOP224Y and is a switch and inspecting it reveals its casing was blowen and one of the leg was separated.
I decided to buy a new TOP224Y and there was only TOP224YN available no more TOP224Y.
The price is $10 something.
With a solder ****** I was able to dismount TOP224Y from the control board,
and when I will receive the new TOP224YN I will replace it.
In the same time I noticed a big diode next to TOP224Y was also overheated and cracked and a small glass diode was also cracked and need replacement. The transformer next to the TOP224Y is called fly transformer I had measured it with an ohm meter, it reads very low nearly zero ohm.
I will receive the new component TOP224YN tomorrow 24/6.
Jun 21, 2008 | Fisher Paykel Eco IWL16
Faulty TV, no picture but sound present
Sorry can't solve the problem... yet. But I have exactly the same problem with the same TV. Sound but no pic, and a toko inverter board that has four 4511GH components that look like they have been getting too hot. I get a ticking noise from the power board when it is running, and that dissapears if I run it without the inverter board attached. Did you get anywhere with the fix? I am not an expert so don't know if it is as simple as replacing these four components althogh its the one between CN6 and CN7 that looks worst. Any help?
Thanks.
Mar 12, 2008 | Televison & Video
Acer Aspire L100 PC Desktop Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
