Question about Zenith Televison & Video
Black screen with audio - Zenith Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Black screen
If you have audio but a black screen then you either have a bad power supply driving the backlights or bad backlights, probably the first if there is audio.
Mar 30, 2011 | Televison & Video
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
GV42L Vizio HDTV Problem
You didn't mention whether you have any audio; details like that can influence the response.
If you have audio but no visible video, look at the screen from an angle for 10-20 seconds to see if any video is present. If you do see some shifting shadows on the screen and have audio, the backlight or its power supply (inverter) has probably failed.
Nov 19, 2008 | Vizio GV42L 42 in. LCD Television
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
88 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
