Question about Sony Cyber-Shot DSC-T1 Digital Camera
When i open the lens cover the display has blurry lines all over the screen
2 Suggested Answers
SOURCE:
  • 41 Answers
SOURCE: when i open the lens cover the display has blurry
Initialize the Camera to check whether the issue is resolved.
Posted on Jul 18, 2010
Blurry webcam
Many laptop computers come equipped with a small web camera assembly mounted above the LCD screen. Like any other camera, these webcams use a lens to take pictures. Over time, it is possible for this lens to become dirty, especially if you have touched it a few times. You can quickly clean the lens and get the unit back to taking crisp pictures.
1.Take a microfiber cloth and gently press it to the lens of your laptop's web camera.
2.Gently rub the lens of the web camera with the microfiber cloth. Be sure that you cover the entire surface of the web camera's lens.
3.Open your web camera program when you are finished and take a picture to test the quality of the webcam. If it is still blurry, close the program and repeat steps 1 and 2 until the web camera is no longer blurry.
Sep 09, 2011 | Cameras
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Blurry Spot
First check lens for any moisture when the cover is open - even dried liquid.
If it is consistent, and you've cleaned the lens, then the CCD may have a fault on it.
This would need returning under warranty if it is still covered.
Jun 26, 2008 | Fuji FinePix A350 Digital Camera
Blurry camera screen
If the pictures are blurry, you probably damaged the lens with the drop. You will have to send the camera to the factory service to replace the lens unit, if it is not serviceable.
If you drop a camera this is not normally covered by the warranty. You may find it cheaper to replace the camera than have any major service done to it.
Jerry G.
Apr 27, 2008 | Cameras
FIXXING A MITSUBISHI DLP 65731 HDTV REPLACING THE PROJECTION LAMP COVER
What color is it over and can you see the scratch enough to tell if its under or over the lens. Yes it is 2 parts but fluid lies in between. For more info ctechnicians.com
Jan 07, 2008 | Televison & Video
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Blurry display after dropping
I did the same thing to my Photosmart E327 and upon inspection, I found that the len had fallen out. I could not find it so I am trying to find how to get it replaced. The blurry picture began for me after the drop. Suggest that you check to see if your len has become dislodged, or fallen out as mine did.
Dec 03, 2007 | HP Photosmart E327 Digital Camera
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Blurry pictures
have u ever send the camera to repair??, that cameras had a faulty lens, and need to be replaced our be repaired. good luck
May 17, 2007 | Olympus Camedia D-425 / C-170 Digital...
Sony Cyber-Shot DSC-T1 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
