Question about Sony KV-32S22 32" TV
32 inch Sony Trinitron tv (10 yrs old) Turned off, won't turn on
32 inch Sony Trinitron tv, about 10 years old: TV screen went dark, looked like it was switched off. No power. Hitting Power button does not work. Breaker and outlet ok. Any ideas?
gopakumarg43
  • 75462 Answers
SOURCE: my sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Posted on Nov 20, 2010
nfandres
  • 168 Answers
SOURCE: Sony Vega Digital TV model KD-28DX50 U
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Posted on Jan 16, 2007
techman
  • 3130 Answers
SOURCE: sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Posted on Jun 23, 2007
Falling Down
  • 67 Answers
SOURCE: Sony Trinitron KV35V36 Glass Chip
fill in the spot with clear epoxy from radio shack. Place shipping tape over the epoxy and turn the screen up if possible to make the repair flat. Wipe off any excess epoxy as the tape is applied. The break refracts the light from the screen away from you and makes it appear dark. Remove the tape after the epoxy sets. Do not open the unit up. The aquadag can hold high voltage for up to a month. There should be no danger of breaking the crt itself if you're careful. Over time, recycling the power on and off may make any cracks propagate but if there are none now it should be ok.
Posted on Nov 30, 2007
SOURCE: tv will not turn on and power up.it just clicks
the tv needs a new tube
Posted on Apr 24, 2010
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony 32'' Trinitron that blinks off and on when turned on
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's wrong with it and how can i fix it?
Feb 07, 2010 | Sony Televison & Video
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
344 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
