Question about Maytag MGR5770 Gas Kitchen Range
Maytag MGR5770 gas stove. The oven shuts off intermittently
I have a Maytag MGR5770 gas stove. The oven shuts off as it is heating up. When it does the control panel - clock/temp etc. goes dark. After a few minutes the clock comes back on and it's possible to reset the oven temperature and start it again. Sometimes it will stay on, but most of the time it will quit again. The whole control panel area gets very hot from the oven vent which is right below it. Could some duct work in the oven have gotten loose allowing to much heat to escape resulting in the over heating of the controls? Or is something else causing the failure? Thanks, Craig
  • 60 Answers
SOURCE: bottom oven does not heat up, top oven works
the most common problem for your description is that your bottom ignitor is not working properly just because the ignitor glows doesnt mean your ignitor is working it has to draw 3 amps or more to ignite the bottom burner part number for the ignitor is 12400035 let me know how you make out
Posted on Sep 12, 2007
SOURCE: Maytag MGR5775QDS oven wont heat.....
Replace the ignitor.  You will need remove the bottom plate (remove the two screws back corners).  And the disconnect the wiring from behind.  This little part will cost you approx. $100.
Posted on Feb 21, 2009
farfield
  • 462 Answers
SOURCE: Maytag gas oven won't hold temperature after 30 minutes of use
The Oven safety valve. Look for it on the base plate below your ignitor. It is a the end of the burner manifold and has 2 wires to it Check it quickly by getting to the point where it acts up. But first, Connect a voltmeter to the 2 wires (if you can with them still connected to the safety valve. When it ignites the voltage will be present. Let it cycle off like you described. Now watch it as it tries to come back on. If you get a voltage reading now that indicates everything else is working and the valve is not opening like it should in other words with the voltage to the gas valve and the ignitor glowing you should have a flame. I assume the ignitor comes back on.
If this helped you please rate me as high as you can. If it did not please restate what problem your having and help me to understand it better. Thank you for using fixya and good luck.
Posted on Mar 24, 2009
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
  • 67 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
you need to replace the oven ignitor
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
WHen turning on the oven to bake it will not ignite a flame. I can broil and cook on top however the gas will not lite when baking. The pilot is on however the gas will not burn unless banging on the part...
This is usually a symptom of a faulty oven safety valve. Over time, it tends to stick internally and banging on it helps unstick it. You can either continue banging on it for faster burner ignition or have it replaced. You'll need the make, model # and sometimes serial # if it's an older model, to replace the part. If you do it yourself, be sure to close the shut off valve behind the stove before you remove it. Douglas
Aug 18, 2010 | Maytag MGR5770 Gas Kitchen Range
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
Clicking sound on my gas stove
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Dec 11, 2008 | Maytag MGR5770 Gas Kitchen Range
STOVE IS SHOWING F-3 AND OVEN WILL NOT GO ON.
most f-3 error codes are for the oven sensor. you sensor is probably bad and needs to be replaced. Joe
Dec 02, 2008 | Maytag MGR5770 Gas Kitchen Range
Oven does not cook food fully.
I researched the Repair Clinic.com site and for the unit in question it drove me to the Bake Ignitor Glow Bar as being the problem. It is 90% sure the problem lays in this part and instructs to R&R the part.
Nov 22, 2008 | Maytag MGR5770 Gas Kitchen Range
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Maytag MGR5770 Gas Kitchen Range Logo
261 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
