Question about LG Televison & Video
'Fly Back Transformer' Arcing in 57'' Rear Projection TV
I've been given a very large 57'' Projection TV on wheels, when it's turned on there is a lot of arcing underneath the Fly Back Transformer for 2-3 seconds and after around 6 seconds the TV returns to standby mode (red light) without actually turning on sound/video.
I had approached a local TV repairer who wanted $80 just to drive up to my front door before even looking at the TV, so I quickly realised I'd need to do this myself. I'm proficient in repairing other electronics and have desoldered the transformer from the board, added insulation around the exposed terminals and resoldered it in there but the arcing is still occuring.
Would it be worth my while in purchasing a new Fly Back Transformer and fitting that? Or could the problem be elsewhere, overloading the transformer?
Any help would be very greatly appreciated.
techman
  • 3130 Answers
SOURCE: sparks arcing from rear of tv
Wow they are charging you alot for this repair my friend. Go to this link and you will see! The High Voltage transformer, also known as a flyback only cost 50.00 Bucks!http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187762&ProductType=PART&ModelID=420798 I would get the part and let someone replace it If you have no soldering and or TV repair experience, as this is a dangerous place to be experimenting with if you do not know the safety issues involved. Good Luck Please dont forget to rate this thread.
Posted on Nov 25, 2006
premtech
  • 934 Answers
SOURCE: RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Posted on Dec 16, 2007
  • 61 Answers
SOURCE: RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Posted on Mar 30, 2008
  • 2336 Answers
SOURCE: Sony rear projection tv How to de-solder
I would suggest not to desolder that transformer until you are certain that is defective.
Try to change D6116 and D6301 first.
You can try Radio Shack or check this site.
Good Luck.
Posted on Apr 10, 2008
  • 2920 Answers
SOURCE: I have a sony rear projection 52 in tv i need help with...
you can do it yourself if you can orer the part..its about 120.00 i think for the powerboard and then th time it takes you to put it in. if a repairman does it hes charging you at least 75.00 an hour for labor.
Posted on Feb 09, 2009
When I turn the tv on it has no pic and then turns itself off but would come on after about 5 times of turning it back on but now it just had sound and no pic.
It seems that your Pulse Width Modulation drive ic on power supply or high voltage section fails. This can be resolve by replacing the IC MCZ3001d that will be found on your power supply or at the high voltage section.(near Fly back transformer) If you have basics knowledge in electronics and soldering, you can easily fix it.
Mar 02, 2011 | Sony KP-57WS520 57" Rear Projection...
Zenith r57w46 rear projection tv
the static sound may be due to a defect in the high voltage circuits, IE Fly-back transformer or and voltage multiplier, posibly high voltage leads to the CRTs arching to ground, finally horizontal sweep circuits
Apr 28, 2010 | Zenith R57W46 57" Rear Projection...
TV wont turn on...red power button flashing
HI. this is a malfunctioning fly back transformer. it is connected directly to the picture tub, and is part of the main power sector as well. The fly back transformer can become covered with lint overtime. this will induce a very violent arcing effect that will usually blow the entire power sector.
Replacing the fly back and affected components will fix this issue.
Jul 30, 2009 | Sony Televison & Video
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS500
8 times flash shows error in Flay back Transformer on D Board.
Fly back Transformer part number is ... 1-453-285-41 FBT ASSY, NX-4006
It is available at Part Store on $112.00
All above info are based on your question and feedback.
Good luck.
Sep 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Rear projection tv picture blurry
HELLO sounds like you need to adjust the focus pod on the fly back transformer. not the screens but the focus on the fly back transformer to see if that clears up the picture. hope this helps. "GOOD LUCK"
Aug 09, 2008 | Televison & Video
Please Help
no its not the speakers, i think it is the flyback transformer that is arcing.
Jun 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Sears tv 774 15580
I have same problem, arcing from horizontal output transformer (fly back trans), sears has no model number in their system, Flyback Transformer needs to be replaced but no luck finding one yet, anyone have suggestions on where to find one, part number BSC29-N1111
Mar 30, 2008 | Televison & Video
Tv shuts off by itself then flashes a code 8 blinks
Eight blinks means, "High voltage error". The probable cause location listed is "T8005 is faulty (D board). T8005 is the fly-back transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
or send in for repair here
if one of the crt is shorted it can also cause this problem.
Jan 30, 2008 | Sony KP-57HW40 57" Rear Projection...
Sparks arcing from rear of tv
Nov 25, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
Computer Repairing
Computer Repairing
