Question about Vision Office Equipment & Supplies
Hello, my problem with the Panini My VisionX, is the following: - After feeder pulls the cheque, when it reaches the second transport wheel, it is slowing down the speen more than 10 times slower untill it will be ejected out, but it stops feeding and giving a message box with text "Done". Try to enter the same cheque again it will do the same thing. Working on Demo version it works 100% properly. Thank you.
SOURCE: No page was found in scanner when one was there
Lift up the black frame around the large soft grey pick rollers on the upper part of the paperfeed until it locks into place. Power off scanner and back on and the trya will lift and the paper will feed.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: paper feeder won't follow through
I found olasNick's comments very worthwhile. I was also having a paper feed problem and carefully disabled my LEX73 and now clearly understand the comments regarding prying it apart. There are plastic clips that hold all of the plastic together, by gently prying and pushing the clips at the same time I was able to get it apart without breaking any plastic. Once inside the problem was obvious, a broken gear on the roller assembly. I guess I could order a new gear from LEX but at this point, I think I'll take it a sign to retire this old workhorse. I think I got this printer about 10 years ago and can't imagine how many reams of paper have gone through this printer. It doesn't owe me anything.
Posted on May 28, 2008
Mike258
  • 1498 Answers
SOURCE: All 4 power windows on 1999 Chevy S-10 Blazer started moving slow and then stopped working.
Hey there Bubba,
Had the the same thing happen to me on that Blazer in my picture. All of them going at once is the key symptom here. What do all the windows have in common?
Check the the window functions from each door/window switch. Any difference in performance from the drivers controls?
The switch itself is usually the problem . Over time the contacts get scarred, worn and unable to transfer current. The drivers controls are used more often, as such are usually the first to develop symptoms.
I'd check out a local wrecking yard for an inexpensive replacement.
Let me know how it goes
Mike
Posted on Oct 26, 2008
Beni S-P
  • 1006 Answers
SOURCE: Problem ejecting/stopping Seagate Freeagent Go 250GB hard Drive
Antivrius or another program using it...You just need to stop all servicess on task menager then stop mass strorage device
Posted on May 10, 2009
mohanchennai
  • 490 Answers
SOURCE: multi feeder not working
Is the document tray raising? If that is okay, then clean the rubber rollers with a damp cloth. If worn out replace.
S. Mohan
Posted on Aug 04, 2009
Panini scanner gives error but no details about what is wrong
Hello. The thing you should do first is, turn off the computer and the scanner. Now you need to do is to disconnect the Panini scanner from the computer itself. Then turn on the computer and uninstall the Panini program from the computer. When your done doing all that, reinstall the installtion program for the Panini scanner, then reconnect the scanner back onto the computer, then turn on the scanner and give it a testrun and see what happens. Good Luck!
Apr 22, 2014 | Vision Office Equipment & Supplies
PRINTER SHOWS NO PAPER IN DRAWER
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
Nov 12, 2013 | Lexmark Optra Office Equipment & Supplies
The driver was not installed. You did not accept the certificate required during installation. (DTD8008)
We have got the same issue too when using the desktop deposit function.
The tech support basically did 2 things to resolve the issue:
  • In Internet Explorer
Oct 05, 2010 | Vision Panini My X 60 Check Scanner
Looking for instruction manual for wolfgang pucks panini maker with removable plates
The knob used for use of the position plates has come completely come apart. Please help. This is the second time I have had trouble with this product. I need a repair picture with instructions on how to put this back together.
Nov 09, 2009 | Wolfgang Puck Panini Maker
Both our brand new copy machines SHARP M316 have problem with the
first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Jun 15, 2009 | Office Equipment & Supplies
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Wheelchair support
First of all, you should be aware of your Center-of-Gravity. Many activities require the wheelchair user to reach, bend and transfer in and out of the wheelchair. These movements will cause a change to normal balance, center-of-gravity, and weight distribution of the wheelchair.
To determine and establish your particular safety limits, practice bending, reaching and transferring activities in several combinations in the presence of another individual BEFORE attempting active use of the wheelchair. roper positioning is essential for your safety.
When reaching, leaning, bending sideways or forward, it is important to use the casters as a tool to maintain stability and balance. When you are reaching, leaning and bending forward, position the casters so that they are extended away from the drive wheels and engage wheel locks.
Never attempt to reach an object if you have to move forward in the seat or pick them up from the floor by reaching between your knees. When you're reaching or bending backward, position wheelchair as close as possible to the desired object.
Position the casters so the are extended away from the drive wheels to create the longest possible wheelbase.
Reach back only as far as your arm will extend without changing your sitting position. When another person is tipping the wheelchair, he should grasp the back of the wheelchair on a non-removable part.
Inform the wheelchair occupant before tipping the wheelchair and remind them to lean back.
Be sure the occupant's feet and hands are clear of all wheels and/or any other pinch points.
Sep 14, 2008 | Jet 1HD Power Electric Wheelchair
Paper transport is failing
You need to clean the paper feeder to remove a film of dirt that is causing the problem, also bend the thick paper on the edge of where the portion is inserted to ease the stress of taking the paper in... Lubricate the gears and traction mechanisms of the paper feeder to function properly and to last longer...
Hope this Fixya the problem... Goodluck
Feb 06, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
370 people viewed this question
Top Vision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
