Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
No power in car
My unit has worked for more than a year in my car. Now it gets no power from the lighter socket. I have tried it with the AC adaptor in my home and it works fine. The lighter socket works with the lighter and with my cell phone charger. The Delphi Vehicle Power Supply looks OK. If there is a fuse, I can't find it. Do I need a new Delphi Vehicle Power Supply?
    Problem Solver:
  • 10 Answers
Re: No power in car
Try a tester on the car lighter power cord( usually auto parts stores countermen will do it) to make sure the cord isnt shorted. It sounds like that might be the problem. Good Luck. I found that if you constantly move the unit from car to home the jacks start coming apart internally. the solder joints break and the connection gets spotty. I am on my second Roady 2 because of this.You can get a T6 tork driver and take them apart if you feel up to it or buy another one on ebay or craigslist of they have one. Good Luck
Posted on Jan 04, 2008
0 characters
3 Points
Engine noise through sirius
First check fo good ground on lighter socket sometimes manufacture's use whats called a floating ground which is one wire connecting every socket for a ground . This creates what is called a ground loop and can create noise. Instead of rewiring try an inline noise filter. check with your local car audio store. Hope this helps. If not write back.
May 06, 2010 | Sirius Satellite Radio sp-tk2 Satellite...
Power Requirement for Delphi Roady 2 XM Radio
Radio shack has a unit that plugs into a 110 socket and will accept the 12V plug that is standard with the radio. I use my unit in the house, car and on my motorcycle. The part number is 22-505 for the Radio Shack part.
Dec 02, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Tao won't start
Dear Jim,
My own Tao unit is dying as well. Servicing does not appear to be available. The only solution I have found is to buy the Delphi MyFi unit which appears to use an identical interface (see page 10: ). What a bummer!
Jul 29, 2008 | Tao XM2go Satellite Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
No Power...Keep Blowing Fuses
you have a live going to ground meaning a live wire is touching another wire or touchin the caseing thus blowing your fuses
regards Doug
Feb 29, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Power but no signal
I work for sirius so I know about all of these different issues and the most common one is the connections. It is imperative that the radios be connected to power with the cig lighter adapter. This adapter had circuitry in it that lowers the cars 12 volts to 5 volts which the sirius unit ooerates on. The old units were 12 volt and could hard wired into the vehicles fuse block, but all of the new radios operate on 5 volts. If this is not the issue with either of you then you have defective units. Being that all warranty replacement are with remanufactured units, your chance of getting a problematic unit increases after the initial return of your new unit.
Feb 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Xm radio
mine does the same thing.
Nov 03, 2007 | Delphi Roady XT XM Radio Receiver
Sportster 4 not working...
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
Oct 13, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
A/C Adapter Noise and Interference
We should sue Delphi for resolution of this problem. I feel that the adapters are a fire hazzard.
Feb 24, 2007 | Delphi Roady XT XM Radio Receiver
Noise with casette adaptor
Well Jill the problem you are having is called inducted noise. The lighter power adapter cord is inducting electrical current to the cord used by the cassette adapter thus creating the the noise you've been hearing. Do your best to separate the two cables as much as possible. I realize that your unit may have both cords coming out of th same side, and that's fine. the longer the run of wire, the easier it is to have induction issues. If the cords do come out on the same side, run one up and the other down away from the other cord. Do not coil the lighter adapter or cord either, it increases the chance of being able to induct noise. If your unit is to close to the lighter assembly you may need to move the unit to another location in the vehicle itself to help combat the noise issue. Other options include to shield the cassette adapter wire, i use aluminum tape for heating/ac ducts. The only other option i can see is purchasing a FM modulator which will transmit the units sound wireless-ly through an FM radio channel. You will want to check and see...i do believe most XM radios have a FM modulator built in. Hope this helps, and good luck.
Oct 03, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
122 people viewed this question
Top Delphi Home Satellite Radios Experts
xxxxxx xxx
Are you a Delphi Home Satellite Radio Expert? Answer questions, earn points and help others
