Question about Cosco Summit 22260 - Houndstooth
Washed the car seat cover and now can not get the straps back in place
  • 20 Answers
If you can roll and tighten them, they shouldnt have ever came off lol.. but other then that, once washed and dried, the cusion shrinks... ive delt with lotsa car seats, im way over protected and cant stay with a seat for more then 4 motnhs lol so let me know and ill see if i can help
Posted on Jun 26, 2009
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
HOW DO THE STRAPS GO BACK THROUGH THE LATCHES? WE WASHED THE SEAT COVER AND WE CAN'T FIGURE OUT HOW THE STRAPS WERE THREADED TO LATCH THE BABY IN THE SEAT
Your not suppose to wash the cover...as bad as it sounds you are suppose to spot clean only... after you remove the cover their not safe any more.
Sep 23, 2009 | Eddie Bauer 3-In-1 with Latch
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Can i wash my covers
sure, remember to only dry with a light air tumble. not extreme heat. the full heated dry will cause shrinkage.
Mar 01, 2009 | Graco ComfortSport 8639 - Grey
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Cosco Summit 22260 - Houndstooth Logo
298 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
