Question about Canon PowerShot SD770 IS / IXUS 85 Digital Camera
The camera will not take pictures. Whenever i try the pictures area black. I can review old pictures but cannot take new ones. What could the problem be?
Reset to manufacturers standard settings?
Posted on Jul 06, 2009
I can not see image on screen
If you can see the picture before you take it, then the taken picture is black - Camera needs repair at a service shop - aligment.
If you cannot see the picture before you try and take it - The lens shutter is jammed. A repair shop is required. Could be $80 -$200+ depending on parts costs and labour.
These are only probable answers.
Mar 21, 2010 | Kodak EasyShare C310 Digital Camera
Coolpix S210. Screen is black in shooting mode. I can review pictures taken.
I'm having the same problem, but I can't review pictures taken, except for old ones.
Dec 15, 2009 | Nikon Coolpix S210 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Black screen
First ensure that this is not a setting problem, by removing batteries to reset camera. try also using the Reset command in the camera menu , after removing batteries.
if you can see old pictures, but new ones come out black, that means that for some reason, no light is coming to the array sensor (the sensor that scans and take the picture), or the signal is not arriving to main board, or the board is faulty.
Check first that the shutter is opening properly, that lens is extending, and that there is no dirt on top of the objective lens.
If that is not a problem, then there is either a defective array sensor, a losen array sensor cable/connector, or the main pcb inside the camera has a fault.
In all cases the camera must be taken apart, inspected, and fixed by a technician.
Dec 17, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
Black LCD screen everytime i turn my camera on
I've had the same problem for a while now too.
The camera has been useless and Im looking to replace it.
Im sure this problem hasnt got a simple fix and im better off buying a new camera!
Id like to here if someone managed to get it fixed thou ?
Thanks
May 03, 2008 | Kodak EasyShare C533 Digital Camera
Outside shutter cover will not open
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Mar 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Black Screen
ok...open up the camera, remove battery and card for photos...then place battery in again, and turn on..see if that helps at all
Mar 09, 2008 | Nikon Coolpix S4 Digital Camera
Canon PowerShot SD770 IS / IXUS 85 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
