My ac is not working.
My 95 chevy cavalier is blowing out hot air again. i put a can of freon and it worked for 3 or 4 days and started blowing hot air. the guage was saying it was over charged after we put that can in. what could the problem be.? how many cans of freon do you put in ? I bought a can of freon with the green flourscent dye in it & i am going to try that to see. how many days do i need to run it before checking it
  • 30 Answers
You should be able to see it immediately
Posted on Jun 26, 2009
My rear air conditioner on my 2011 Traverse only blows warm air. Front air works good
clogged air condition filter leading to rear unit Possible LOW on FREON
Aug 20, 2014 | 2011 Chevrolet Traverse LS
2009 chevy AVEO 5 ac blows hot air
The guage needs to read between 35/40 psi.. If its much higher you may be overfull, this causes it to not cool.. Fix by letting some freon out, then top it back to needed pressure.. If pressure is correct, it would be a clog in the system.. Usually an orafice tube or accumulator..good luck!
Apr 09, 2014 | 2004 Chevrolet Silverado 1500 Crew Cab
What's your problem?I have a 1996 Chevrolet Suburban. The AC is blowing out hot air. I have had the truck for 6 years, every Summer its the same thing. The ac does not get cold, I take it to the m
To clarify - - if the truck has rear and heat, you have two heater cores and two evaporator cores. The evap cores carry the freon.
If the leak is in the evap core in the front, the price is probably right.
Jul 06, 2012 | 1999 Chevrolet Suburban
AC ran for a couple of hours and started blowing
If it is icing over, it is low on freon. You might have a freon leak if the system is relatively new. It will take a licensed tech to check, fix leak and recharge.
Aug 25, 2009 | Fedders AEQ07FBG Air Conditioner
Ac not working, blows hot air only. Recharged
Check the evaporator coil by sniffing the vents,floor is best, with your tester.
Jul 15, 2009 | 2005 Dodge Ram 1500
A/C blows hot on 1999 Chevy Cavalier
That could be the case. The other problem could be that you are losing freon for some reason. Find someone who can check the freon level for you to make sure that it is not leaking. The valve to fill the freon can get bent which allows for the gas to escape and then you run into this problem.
Jun 03, 2009 | 1999 Chevrolet Cavalier
1999 Chevy Cavalier A/C blows hot air
More likely the recharge blew a o-ring and you have a leak. When your Cavalier was blowing hot air and a recharge fixed it that means it was low on freon which lets o-rings dry out, go back to the shop and have them leak test it. They use a pressurized dye to find the problem. If it's blowing it's not the cooling fan relay, they may have meant compressor relay but I'd have a leak test done first it's not expensive and easier that chasing unknown possibilities.
2001 cavalier air conditioner blowing hot air
Why do they want to replace the compressor?noisy?If you can put a charge on the ac then it's hot again after a day,then you have a leak.all the ac lines have o-rings where they are connected.without put dye in the system you wont know for sure.So I would try that first.
May 25, 2009 | 2001 Chevrolet Cavalier
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
