Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
