Hp2015dn the light next to the triangle is blinking. sometimes the printer will print everything and sometimes it will drop a print job or two; then we have to push buttons for the printer to print again
    Guru:
  • 224 Answers
Photosmart c8180 or the officejet J4680 all in one printer
Posted on Jun 26, 2009
    Guru:
  • 224 Answers
INsert the cd and exit out of the autorun menu.
Click on start.
click on my computer.
right click your cd /dvd drive and click on open
go into the folder called "util".
then go into the folder called ccc
double click on the file l1 uninstallation.
it will uninstall the bad printer drivers.
then it'll ask for a restart of the computer.restart the computer.
now right click the cd/dvd drive from my computer and click on open there will be a file called setup with a blue and white hp logo double click that file and then select the option add a device or install and follow the onscreen instructions.
If you do not have the cd goto hp.com
click on the tab called support and drivers click on download drivers and software.
enter your printer name and click on go.
select your operating system .
then select the option that says basic print and scan drivers.
download it to your desktop and run it.
once it has extracted then exit out of the hp splash screen that will give you installing options....
Now click on start and click on run.
type in %temp% and click on enter.
now locate either of the files in brackets.
(hp web release) or (7z) this folder would begin with this name.
double click the folder
then it will ask you to restart the computer so restart the computer.
then click on start and click on run.
in run again enter %temp% and click on the enter button on your keyboard.
again go into the folder that begins with 7z or the folder called hp web release(either one).
go to the bottom and double click on the file that has a blue and white hp logo and is called setup and follow the on screen instructions and this should resolve your problem.
If you still face the issue after this it may be a hardware issue with your printer so call in to hp's toll free number at 1800-474-6836 and you will get agents to assist you with a 50% discounted upgrade printer ro troubleshoot your printer issue further or something or the other.
The printer does not accept print jobs and orange warning light is on along with green ready. Both lights sart blinking when a printing job is sent. The printer does not print. How can I fix the probl
Dear
I am not familiar with Ubuntu. So in case of windows SMART PANEL/EASY PRINTER MANAGER can be down loaded from samsung web this will show the errors that the machine has.
Try to print a self (demo page) pressing stop s/w a while. If it works check the life of toner cart.
Thanks.
Sep 19, 2014 | Samsung ML-2571N Laser Printer
Machine has an error code & won't print. We have no manual.
If the lamp is on solid that is a cancel job or reset printer indicator
If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
1 blink - jam in feeder sensor
2 blink - jam in manual feed
3 blink - jam under toner
4 blink - jam in output are
5 blink - jam in tray 1
6 blink - jam in tray 2 (if present/option)
Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
The exclamation sign flashes and then the green light but no printing
The service Manual says that if both the ready (Bulb) light and the exclamation light are both on it is a invalid engine
code /Invalid network code. But to clarify that you say they are both on and solid and not blinking. If they are you have a bad main board.
If they are blinking then the error is a Flushing /Resolution reduced error.
The cause is:
Printer is processing data or printing pages,but the resolution of a page in the current print job is reduced from 600 dots per inch (dpi) to 300 dpi to prevent a memory full error.
Solution is:
Wait until the ready light is displayed to print other jobs.
• Press and release the triangle button to cancel print job. It is the lower of the two buttons.
• Press and hold the traiangle button again to reset printer.
Hope this helps
Bruce
Jul 14, 2009 | Lexmark E232 Laser Printer
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Error message unable to print
1.The printer is asking you to manualy load the right size paper.
source tray possibly tray 1
2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages.
3.you are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
Jan 02, 2009 | HP LaserJet 2550L Printer
Printerndoes not respond
I thought my printer died on me, but it turned out it was a simple paper jam. The whole printer just locked up because of a paper jam! All I had to do was open the top compartment, remove the toner and get rid of the paper jam
Jul 25, 2008 | HP LaserJet 1320n Printer
Cannot remove yellow blinking light
does the printer cycle?
unplug the power from the outlet and plug back in.
Can you look and see any paper inside?
when you lift the cover does the cartridges move?
Dec 06, 2007 | HP DeskJet 690c InkJet Printer
Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Feb 14, 2007 | HP LaserJet 1320 Printer
137 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
