Question about Home
A small top fell down my bathroom sink how can ''I'' get it out?
  • 30 Answers
Take off U-shaped P-trap under sink. It should be in it.
Posted on Jun 26, 2009
Which is a good quality brand and model sink for a bathroom?
Kohler k-2355-0 Archer Undercounter Bathroom Sink
Overview
Kohler has become a warm trend in light commercial and residential bathroom and restroom design in recent years. The Archer undercounter toilet features the transitional aesthetic of the Archer Suite, blending subtle design elements create in craftsman furniture's chamfering methods and the intricate surfaces of jewelry.
This mixture of chamfered edges and curved bases create an endless appeal that suits a collection of design ideas. If you are looking for top recommended Archer Undercounter Bathroom Sink, then KOHLER K-2355-0 Archer Undercounter Bathroom Sink is my suggestion.
The KOHLER K-2355-0 Archer Bathroom Sink, completed with a lot of competences which makes it great product. This sink provides clamp assembly classic rectangular basin which is 19-7/8?L x 15-5/16?W x 7-1/2?H.
Specifications
  • Installation Type: Undermount
  • Basin Depth: 3.75"
  • Basin Width: 13"
  • Basin Length: 17-5/8"
  • Material: China
  • Number of Holes: 0
  • Shape: Rectangle
  • Style: Contemporary/Modern
  • Texture: Polished
  • Drain Outlet Connection: 1-3/4"
Mar 17, 2018 | Home
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
My bathroom sink keeps blocking up any cures ?
its hair caught in the strainer inside the top half of the tailpipe. You can pull the pop up out of the sink and run a hanger down and try and remove the hair. But soap and hair together is ALWAYS the problem.
Mar 14, 2012 | Plumbing
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
Aug 05, 2010 | American Standard Home
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Mar 11, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
Something fell in the bathroom sink and there is a small hole in it.it is cream enamel and i want to fix it
Go to either home depot or lowes back in the plumbing section there are repair kits for chips and cracks.
Mar 05, 2009 | Home
Home Logo
112 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
