Rjk5020 both 8 amp fuses are blown
  • 25 Answers
Vizio there ausim! or replace the fuses after you unplug it
Posted on Jun 26, 2009
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
Dec 25, 2015 | Lexus GX 470 Cars & Trucks
What fuse controls the blower motor and cigar lighter
You people need to list the year, make, model, & engine size, when asking a question. It helps when we know which vehicle it is.
All I can tell you right now, is take of the cover to the fuse box, it should be marked on the inside of the cover. If not & your blower motor & cigarette light are both not working & you suspect a fuse,
you will need a test light, clip it to a good ground, then with the key on (motor off) touch the little metal taps that are on each side of where it states the size of the fuse, the test light should light, when you touch each tab, if it only lights on one side, then that means that side is the hit side & the fuse is blown preventing the current from traveling to the other side to feed the power to whatever circuit your testing. One you find the blown fuse, you can pull it & see it's blown
Jan 06, 2015 | Cars & Trucks
Blown fuse on JBL amp
Are they inside. I ask because I just looked at pictures of the JBL GTO504 and there are only 2 fuses on the outside of the case. They are standard car type fuses with the current rating printed on them, looks like 20 Amp. You can just pull them out and replace them but you really need to find out why 1 has blown before replacing it.
Amp Pics Here.
May 11, 2012 | JBL GTO504 Car Amp
Sharp R-246 microwave the fuse inside has blown. What amp should it be as I can't read it.Thanks
Hello & Welcome to FixYa
Sharp R246 fuse is Voltage: 5K (Volts). 0.75 Amps. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Microwave Ovens
How can i tell if my amp is blown
check your amps fuses if they are blown thats your problem also check the fuse underneath the hood from the cable going to the amp if that fuse is blown fix it. that will turn ur amp back on. also if your blue remote wire is loose it will not tell the amp to turn on. thats how u can tell. if all fuses are intack. and blue wire is then its blown
Mar 19, 2011 | Car Audio & Video
Amplifier do not have sound. E-mail: rigo11us@yahoo.com
You may have blown the inline fuses for output sound. Amps have alot of fuses under the hood. take the amp cover off and check all fuses are not blown / wire broke inside fuse. Some fuses are hidden under circuit boards on some amps, check everywhere possible to check all fuses. If all fuses are fine and no broken wires inside them, you may have loose connection where your speaker wire ports are inside the amp. Check they arent black or loose. if they black they are blown as there usually soldered (a silver colour)
Mar 02, 2011 | Yamaha AX-596 Amplifier
My interior lights & remote just stopped working
Can be a blown fuse, Check your owner manual for the appropriate fuse that refer to what it is for such at lights, radio etc... and the location of where the fuse in located. Once you find that out, pull the fuse out to see if the fuse is blown, if it is blown replace it with the correct fuse amp. Sometimes there are couple of fuse that are reference to the same details too.
Jan 14, 2011 | 2006 Toyota 4Runner
140 amp fuse blown request replacement instructions
you have to remove or access the bottom half of under hood fuse panel to remove bolts on teh bottom of that fuse.
May 17, 2009 | 2004 Toyota Tundra
No sound
check ur fuses box for a blown fuse or if ur amp has a fuse check that as well and if blown u might have to change ur fuse if not ur amp is blown
Feb 18, 2009 | Car Audio & Video
Televison & Video Logo
1,091 people viewed this question
Top Televison & Video Experts
