Refrigerators Logo
Posted on Jun 26, 2009
Inglis fridge 1993
Fan blower behind the compressor that fan didn't start when cmpressor runs longer ..pls let me know soon as possible in hours not tomorrow thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
76
Points
Model cmp622e craig mp4 player does not started.
Compressor start no longer working then stop cooling?
    There are several possible causes when a refrigerator doesn't keep your milk cold or your ice cream frozen. Before you attempt more complex repairs, try these simple fixes if your refrigerator is not cooling and if your freezer is not working:
    ·Be sure the fridge is plugged in and getting power. The light should come on when you open the door.
    ·Check the thermostat to make sure it hasn't been turned way down by mistake. If your fridge/freezer thermostat isn't working.
    ·Be sure the vents on the back of the freezer compartment aren't blocked by boxes of ice cream or frozen vegetables-the vents have to be clear for cold air to circulate.
    ·Vacuum the coils under or behind the fridge. Clogged coils can cause poor cooling.
    ·Check to make sure nothing is stuck in the condenser fan and that it spins freely (models with coils on the back won't have a fan). To do this, unplug the fridge and pull it out. Clean the fan blades and spin the fan by hand to see if it's stuck. Plugin the fridge and make sure the fan runs when the compressor is running. If the fan doesn't run, see the directions below, which show how to replace it.
      Replace the Refrigerator Evaporator Fan
      ·Here are some refrigerator troubleshooting tips to help you zero in on the problem if you notice your fridge not cooling. If you can hear the compressor running but the fridge isn't cooling, the problem is most likely either frost-clogged evaporator coils or a stuck or broken evaporator fan. Evaporator fans often squeal or chirp when they start to go bad. You'll know it's the evaporator fan if the noise gets louder when you open the freezer door. The evaporator coils and fan are located behind a cover in the freezer compartment
      ·If you remove the cover inside the freezer and find the coils completely filled with frost, take everything out of the freezer and fridge, unplug it and let it thaw for 24 to 48 hours. Keep a few towels handy to soak up water that may leak onto the floor. When all the frost is melted away, plug the fridge back in. If it works, the problem may be a defrost timer, defrost heater or defrost thermostat. Replacing these parts isn't difficult, but figuring out which is faulty requires troubleshooting that we won't cover here. Call a pro if you suspect a problem with these parts.
      ·Normally the refrigerator condenser fan and compressor, located near the floor on the back of most refrigerators, come on when the thermostat calls for more cooling. If you don't hear the compressor running after the door has been left open for a while, it could mean the condenser fan is stuck or worn out or that the relay or compressor is bad.
How does a side by side domestic fridge work
New side by side layout is fridge side by side upper 2/3, with lower 1/3 pull out freezer
Normally in modern frost free systems only the freezer has the evap, and the fridge thermostat operates a duct, allowing freezer air to blow into the fridge.
The compressor runs until the freezer is satified, the thermostat powering the compressor is only connected to the freezer. If the fridge requires cooling but not the freezer, there's plenty of freezer air to circulate into the fridge after the compressor has turned off. Eventually the cmpressor will start again when the freezer temp gets too high.
On twin evap models, the fridge fan motor cuts out when the fridge gets to it's setpoint, so no air circulation through the fridge evap, though liquid refrigerant flows through it to the freezer evap. Likewise, if the fridge needs cooling but not the freezer, then the compressor will start but the freezer fan motor will not run.
Old school cyclic defrost systems had the thermostat in the fridge, and the freezer kept running until the fridge coil was low enough to make the fridge cabinet down to temp.
Refrigerator Wikipedia the free encyclopedia
Fridge is not cooling/freezing properly. have tried to clean vents and coil(floor level) by removing grill and using vacuum wand also cleaned some vent in rear. model #TFX24CR. It is still keeping...
One additional thing to check is behind that rear vent behind that cardboard covering for the compressor. See if the fan motor next to the compressor is clean and the fan seems to running at a high speed. If that fan motor is running but doesnt seem to running as fast as say a table top fan would be running,go ahead and replace that fan motor.
Gene
In between doors on side by side fridge is hot. Whirlpool GD5phax
you need to fix the fan down by compressor as it cools the cond coils and causes proper orp of cmpressor . if it not running the comp runs too hot and does not pump the refergent and may be shutting of on overload . the high tempt between the doors will be less with fan working . but some warm tempt is normal .. mm
Hi i have a problem with the above fridge/freezer all the lights are on it makes the appropreiate noises at the right time the fan is working fine no previous problems but now the fridge and the freezer...
Hi, if the freezer fan is on, you need to get behind it and remove the panel where the compressor and condenser coil and fan motor are located. They both should be up and running also. If not, feel the top of compressor and see if it is hot but Carefully, they can get very HOT. If the fan motor is not running, that will be the problem. If it is, see if the front of the coil is dirty, like a sheet of dirt on it. Clean it. If the compressor is hot and off, and fan is running, the compressor is off on external overload. Locked up.If it tries to start you can hear it click off and back on. This is the overload. More then likely, the compressor will be faulty. If the motor is off, replace it and it will work as soon as the compressor cools down. Unplug it if the motor is bad. You can get one at a appliance parts store. Take all part, model, serial, numbers along. Check these out and keep me posted.
Sincerely,
Shastalaker7
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
1helpful
2answers
Hello, We just bought a used ktrs20kawhoo KitchenAid top-freezer,that doesn't seem to be getting cold in fridge section. Freezer is fine. Does it automatically cool top first? The air vent is very small in...
Need to make sure both fans are working and the compressors is running all the time the fans are. If not we need to check the compressor for overheating and look behind back panel in freezer for frost build up. Let me know if you want my help, Sea Breeze
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
3helpful
2answers
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
