Question about Samsung DVD-V4600 DVD Player/VCR
Why does angle-timer and menu will not work but record does?
How do you delete a program that is mistakenly added to the record every episode mode
The easiest way I know is to press menu, then daily schedule. Find the program in question in your list. Click on that program and you will se a window "timers", click on that and you will see "delete", click on that. then you can reset your program to record the way you want. You can also follow the same proceedure, click menu, then daily schedule, then click on "timers". Scroll to the timer you want to delete, click on it, then click on delete.
May 02, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Is there a way to set the DVR to record only on TV 1? I share with another couple and their recordings are messing with my TV viewing on TV 2.. Thank you
utdivemaster
When timers are setup, it will record by default (unless it is changed) to TV 2. You can go into the receiver menu by pressing the Menu button on the remote. This will bring up the Main Menu on TV 1. Press 8 (Preferences) and then 5 (Record Plus). Just change the Record Preference to TV 1 instead of TV 2. If 2 timers are setup and they overlap, it will record to TV 2. I hope this helps.
Ray Calo
DISH Network
Feb 15, 2011 | DISH Network ViP722 DTV Receiver /...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Timer
You can schedule for automatic recording, specifying the start time
and end time of recording. When the timer-controlled recording
completes, the setting is released.
In Menu mode selection... SET, On, OFFAfter selecting SET, press the PLAY button to set the time to start the recording.
Apr 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Timer recording
If the internal clock is not correct, it probably wouldn't let you time record because it would record at the wrong time. Maybe there was a power surge and it caused it to clear the time?
Try setting the time through the menu and if you need a manual, call 1-800-SAMSUNG (if you haven't done that already).
Dec 05, 2008 | Samsung CXJ1364 13 in. TV/VCR Combo
The one for all remote control model urc-7562 funtion on the menu doesnt work what could be the problem?
Hello Stephendo394:
Here are some advanced codes that were found on Remote Central.com web site.
003 Menu
004 Timer Recording
010 Timer Recording
024 Shutdown
026 Shutdown
036 Skip 30 sec
039 Next Page in Menu/Next Track in Play mode
041 Previous Page in Menu/Previous Track in Play mode
043 Time Slip
053 Record
055 Play
061 Right
065 AV
070 NTSC/PAL
076 Language Right
080 Language Left
084 Source
091 Source = SD
100 Playlist View
101 AV
105 Tape Speed
106 Advanced
116 5
117 1
118 7
119 3
120 6
121 2
122 8
123 4
124 Setup
127 Picture Info
140 ?
146 Record
148 Channel Down
152 Channel Up
162 HDD Management
164 Delete
178 Record Flexi-Mode
179 Source = DVD
180 Rewind
181 Returns to Menu
182 Pause/Play
183 Rewind
184 Forward
185 DVD In/Out
187 Forward
189 Context Menu
191 Enter
192 Up
193 Return
194 Left
197 Guide
198 Info
215 ?
219 ?
229 Create Chapter
230 ?
234 Display
245 9
249 0
Aug 20, 2008 | Televison & Video
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
HP 48gx
If you are using the TDS software it may be in the backsight menu - try changing your angle to angle right- if not already set up that way - should work
Feb 22, 2008 | HP 48gx Calculator
Timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Mar 08, 2007 | Zenith TVBR1322 13 in. Combo
Samsung DVD-V4600 DVD Player/VCR Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
