Question about Samsung WF337AA Front Load Washer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
  • 15,935 Answers
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
    New Friend:
I just had this problem and managed to "trick" the Samsung Front Loader into letting me open the door.
1. Turn off the machine.
2. Turn the machine back on. The UE message will be gone now, but the lock light remains.
3. Spin dial to "Spin" cycle.
4. Press "Spin Speed" Button until "no spin" is selected (after 1200, 800, 400 a symbol of a swirl with a cross through it appear at the bottom which is no spin".
5. The timer will now read "1". After one minute the door lock will disengage and you can rescue your clothes or redistribute the weight for better balance and start a new cycle.
Posted on Sep 07, 2013
  • Mardi Shakti
    Mardi Shakti May 28, 2014
    Rae, not only was that "helpful" - it was hilarious!! What a washing machine, hey ;) Thank you; on our washing machine, we were able to turn the power off, then on, then turn the dial straight to "Drain", with the \'1\'. After it was done, we were able to rescue the washing! YAY!!
    New Friend:
Step: 1 Turn off and unplug the unit from the power outlet Step: 2 Check the Shipping Bolts (Make sure they have been removed) Step: 3 Check if the Washing Machine is installed on a level ground Step: 4 Perform a manual drain procedurea. Open the debris filter hatchb. Pull out the emergency drain tube (if applicable)c. Point the drain tube into a basin, and then remove the stopper at the end of the tubed. Dispense all of the water Step: 5 Open the door, take out the clothes, put them back in, and then close the door. Step: 6 If the issue persists, inquire about the Warranty and Service Booking procedures for the unit.
Posted on Dec 01, 2014
2 Suggested Answers
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Posted on Oct 25, 2009
UE Error Code
The UE error code (Unbalanced Error) displays when you wash items that cause the machine to shake badly during the spin cycle, if possible wash and drain the items only, then open the door and stack the items evenly on both sides of the drum in order to balance it, now select the spin cycle.
Dec 26, 2013 | LG WM1812C Front Load Washer
Samsung j1045 washing machine
Oct 14, 2012 | Samsung Front Load Washer Control Board...
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
My samsung smart wash, when it gets to the spin cycle nearly always comes up with error code UE which I know means uneven, I try to rearrange any laundrey or remove some clothes from the machine but it...
Hi, I have a Samsung smart wash 12455 washing machine and My missus has forced thwe door on our washer and it will not open now. Can you tell me how to get the door open as it is now very loose when pulling on the door open mechanisium..
regards,
Steve.
Apr 09, 2008 | Washing Machines
Samsung WF337AA Front Load Washer Logo
6,044 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
