Question about Vantec Fan Vibration Dampener Noise Reducer
Fanning system has become noisy. Dell vostro A860
After about 3 months after purchase the fanning system of my vostro A860 is making noise like it's scratching on something. Am duabooting with ubuntu 8.04 and windows vista. I have no other problems. When i run the dell diagnostics cd it told me the fan was functionning properly and so did the onboard diagnostics test.
Mine too! I;m going to replace the fan and go from there
Posted on Mar 08, 2010
It is making a humming noise
Rear projection TV's have fans that can become noisy with age also the colour wheel motor also can become noisy. Replacing the fans should be easy and cheap, the colour wheel motor not so much.
Dec 24, 2014 | Samsung HLN5065W 50" Rear Projection...
Dell dimension 5150 the fan is really noisy and sounds like its going full blast all the time.we can hardly hear the telly over it.
Your fan is most likely in need of a cleaning, or straight out replacement. You can remove the retaining screws and pull the fan out as a complete unit and blow it out with a can of compressed air. If the noise is a high squealing sound, then I would purchase a replacement fan and install it. Fans can be purchased from Ebay, just remember to check and make sure that you are ordering the correct fan (case or heatsink) before you commit to buy.
Aug 25, 2010 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Thought it was the western digital harddrive,bought a new harddrive and the problem is the same. The computer when running gets very loud. Now I am wondering if the problem is actually the power supply....
Your P.C. may need cleaning inside, Dust may of gathered in Fans, HeatSink, etc. When you connect things to your P.C. normally extra power is needed from help run the process. Hence why your P.C. gets more noisier and things get hotter needing the fans to cool them. Or your Power Supply Unit (PSU) replacing for more Watts.
Aug 22, 2010 | Dell XPS 200 PC Desktop
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Replacing a fan
download
DELL INSPIRON 1525/1526 SERVICE MANUAL
here:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/sm.zip
on sysboard.htm
you´ll find the solution
May 07, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Optiplex GX240 performance problem and fan noise
The fans on Dell power supplies are rather noisy and prone to failure. Find out if the noisy fan is inside the case or inside the power supply. If your computer has become slow you should scan for viruses and spyware. If the scan does not improve things it may be time for an upgrade.
The GX240 only supports up to 1 gigabyte of RAM, you should have the maximum installed. I would not spend more than $50 upgrading this computer, you can find better used ones in the $100-$200 range.
Mar 17, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Noisy system fan
Here are a couple things to check.
  1. Are there other fans (other than the one you replaced) in the system? Many times, even with systems that use one main fan to cool the CPU and case, there can still be a fan within the power supply. There's a good chance that the power supply fan is the noisemaker. Also check for a fan on the video card.
  2. Check to make sure there are no wires or debris that could be lying against the fan blades.
My guess is #1 is the culprit.
Mar 16, 2009 | Dell Dimension E521 PC Desktop
Noisy fan
the 100% noisiest fan is the hardware things and the svchost is the software problem...first thing you can check the svchost to remove the malwarebytes or trojan remover..second things you can fix the noisiest fan by cleaning the fan or replacing the fan.
Mar 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Vantec Fan Vibration Dampener Noise Reducer Logo
884 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
