Question about HP Laserjet M1319F Laser Multifunction Printer
Same ****! after firmware update fax was crashed.... how to restore previous version?
    Champion:
  • 220 Answers
Once you have downloaded latest firmware you can't revert to old firmware unless main board replaced
Posted on Jun 26, 2009
The printer is displaying error: B0605 on the screen
HI............
Issue Description: Print cannot boot up into ready state with an error message shown on printer control panel. The error messages include ERROR: B0601/ B0602/ B0603/ B0604/ B0605. Root Cause: Firmware crashes. Note: Inappropriate behavior may cause firmware crash. For example, a printer is turned off when critical firmware update is undergoing. Solution: Firmware Update Utility.
There are two use cases when encountering the issue: Instructions for Use case 1: driver is previously installed on PC
  1. Place printer in bootcode mode.
    1. Hold down the Cancel and OK buttons.
    2. Power on printer.
    3. Continue to hold down buttons until control panel dislpays Hewlett- Packard on the first line and Bootcode on the second line.
  2. c01688132.jpg Please observe the printer control panel and verify Downloading Update Data is displayed on control panel followed by Programming App Flash; please wait for upgrade utility to finish. Printer would be restarted automatically and the control panel display would show Ready .
Then the firmware is now successfully recovered. Instructions for use case 2: driver is NOT previously installed
    1. Insert printer installation CD.
    2. In Windows OS, please go to Start , Settings , Printers and Faxes .
    3. Click Add a printer to start Add Printer Wizard as shown blow and click on Next button. c01688133.jpg
    4. Check Local printer attached to this computer box; uncheck Automatically detect and Install my Plug and Play printer box and click on Next button. c01688134.jpg
    5. Select FILE:(Print to File) in the Use the following port: dropdown list and click on Next button. c01688135.jpg
    7. Browse to the CD drive in which the printer installation CD is inserted previously and click OK button. c01688137.jpg c01688138.jpg
    8. Highlight the HP LaserJet P2050 Series PCL 6 found in the printer installation CD and click on Next button. c01688138.jpg
    9. Specify the Printer name and click on Next button.
    10. Select No for Do you want to print a test page? and click on Next . c01688139.jpg
    11. Click the Finish button and allow driver to install as shown below. c01688140.jpg
    12. Verify printer is listed in Printer and Faxes window as shown below: c01688141.jpg
  1. Place P2055 in boot code mode:
    3. Continue to hold down buttons until control panel dislpays Hewlett-Packard on the first line and Bootcode on the second line Printer is now in bootcode mode.
  2. In the Printer and Faxes window, right click on the HP LaserJet P2050 Series PCL6 icon and select Properties .
  3. Click the Ports tab and view the USB ports as shown below.
    NOTE: If more than one (USB001) please take note of all listed ports, as other installed printers may have USB ports (USB002, USB003, etc). c01688142.jpg
  4. Close Properties window.
  5. Plug in USB cable from to PC
  6. The Found New Hardware Wizard will pop up, and tje printer USB enumeration will happen.
  7. Open printer properties and select Ports tab again.
  8. In ports tab, tick the correct port that the HP LaserJet P2050 series printer is enumerated on and click OK . c01688143.jpg
  9. Click Cancel on Found New Hardware wizard window.
    NOTE: Not the driver is installed and it is pointed to correct USB port.
  10. Run HP LJ P2055 Firmware Update Utility.
Sep 21, 2011 | Computers & Internet
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Slim psp 2003 chickhen my psp i didnt mean it that i update my psp in version 6.31 how to restore the updated version 6.31 ton5.03
There is no official way to return a PSP to a previous Official firmware. Unfortunately you will have to bear with the firmware you have updated to.
Aug 20, 2010 | Sony Video Game Consoles & Games
I just upgraded to 3.1.1 on my ipod touch 1g. an error message popped up in itunes and my ipod is now stuck at the "connect to itunes" screen. it does not show up in itunes. resetting it does nothing.
Had this problem with itouch 2g as well. Managed to get it back to the way it was like this:
Log onto another account that does not have the 3.1.1 software downloaded. Hold down the Home button and double-click the itunes icon. Wait for itunes to start and it should recognise your ipod is attempting to restore. It should restore it to the previous free firmware version. When itunes prompts you to name your ipod, close itunes, log out, unplug the ipod and log back into your original account. Start itunes and plug the ipod in. It will offer to restore your settings. Restore your settings but refuse the update to firmware 3.1.1 It will then synch as previously.
Still looking to see if there's a way to get 3.1.1 working!
Sep 13, 2009 | Apple iPod touch
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
USB printer crashing thin terminal when 'out of paper"
Wyse ThinOS firmware updates are chargable, or you need a maintenance contract in place for major firmware changes.
Going from 6.1 - 6.2 would be chargeable, but getting the latest version of the firmware version you are currently on should be free.
You are best off talking to your reseller or Wyse
Oct 20, 2008 | WYSE S10 (90210501) Network Terminal
Psp firmware latest version has updated, after that my game can't to play as before, how to restore back my original psp firmware version as original or any guide to resolved my problem
Try a restore default settings. If you are updated to the latest official firmware and trying to run a game from a memory stick it wont work. As official firmware wont support playing backup games from the memory stick
Jul 23, 2008 | Video Game Consoles & Games
Rollback to previous firmware update
yes set to factory settings but i dont know if it will go back to the previous one
Nov 20, 2007 | Sony PlayStation® 3 (60 GB) Console
Display Codes
Updating the Firmware Unlike other machines with removable EPROM (Erasable Programmable ROM), this machine is equipped with an F-ROM (Flash ROM). F-ROM offers the flexibility of quick and easy firmware updates, creation of a master firmware card, backup and restore of firmware and machine parameters. The following is the basic procedure to update the firmware of the machine. The details are described in the Firmware Update Kit User?s Guide. (Order No.: DZTP000019)
Apr 09, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
HP Laserjet M1319F Laser Multifunction Printer Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
