Question about Car Audio & Video
TOYOTA AUDIO MODEL AD6901
MY CAR STEREO BECAME MUTE SOUDENLY IS A TOYOTA AVALON 2004 FACTORY AND I DID TRY TO FIX I DO VELIEBE IS THE MEMORY LOST
  • 1,800 Answers
Yes it is
Posted on Jun 26, 2009
Does anyone know the wiring schematics to the factory radio in a 1999 Avalon XLS with the 7 speaker system
Only the electric wiring diagram has 360 pages. Impossible to post anything of that here. Sorry
Mar 13, 2015 | 1999 Toyota Avalon
Avalon radio
I would check the connections on the grid, if they are ok you have to live with yagi effect.
Mar 25, 2014 | 2000 Toyota Avalon
Toyota Avalon 2004 radio do not work. It turns on but no sound. Some people say may be amp problem because speakers works.
The amp should have it's own inline fuse but if there is no sound it could also mean the radio has died or antenna is disconnected. Any stereo installation shop can find the problem without too much cost.
Oct 25, 2013 | 2004 Toyota Avalon
Location cabin filter 1999 toyota avalon
I show the first year for cabin filters used in Toyota Avalon cars being 2000 not 1999.
The 2000 model filter is behind the glove box.
Feb 18, 2013 | 2004 Toyota Avalon
Need car stereo color codes for 1996 toyota avalon xls v6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope helps (remember to rate and comment this free answeer).
Jan 06, 2010 | 1996 Toyota Avalon
I want to upgrade my stereo in my 1997 toyota avalon but don't know if I can bypass the security -it says that the radio will not work if it is removed. Does it mean the factory radio or any stereo I put...
Hi.
The 'factory' radio has the security feature built into it.
You can add any type of aftermarket radio with no problems.
Thanks for using FixYa!
Nov 20, 2009 | 1997 Toyota Avalon
Need help with wires
This is from a 2004 Solara, but it's probablly the same.
2004 Toyota Solara Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Dark Green
Car Stereo Dimmer Wire: White/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
May 25, 2009 | 2006 Toyota Solara
I just acquired 2005 toyota avalon limited, I noticed when you switch on the radio(audio) and the CD it plays but there is no volume.  Even the volume and mode control on the steering wheels is equally not...
it being an avalon it is a higher end car. a lot of cars these days have external amplifiers factory installed. I would start checking fuses. it might be an aux power fuse or it might have radio fuse. they generally have two fuses that power them though. one that supplies 12 volts continuously so that all presets remain in memory, and the 12 volt switched power source that tells the radio that the key is on. I know that you said that the radio is functioning properly just no sound but your best bet would be to just start checking fuses. there is a fuse box inside car and also a fuse box under hood. you generally have to remove a small black cover and you will see the outside fuse box. when checking fuses though pay attention to anything that isn't working such as the cigarette lighter or horn, these are sometimes the power supplies to the radio. hope I didnt confuse you but an 05 is kinda too new for you to have a bad radio. more than likely something little just one of those aggrivating little jobs of finding what it is.
Jan 23, 2009 | 2004 Toyota Avalon
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
