Question about Hayward 250kbtu Ng Pool Heater - Inground
H250 inground pool heater turns on 5 seconds shuts off flsahing 1f
  • 990 Answers
This is a code for ignition falure. If you are getting a pilot then it means your Ignition module is not sensing the flame and shuting the gas down. This could be pilot wire burnt and grounding or a pilot flame not reaching the sensor or a bad ignition module. This is the expensive part so look into the other things first. Good luck.
Posted on Dec 10, 2009
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
H250 water pressure switch tube how to replace
remove top remove tube from pressure switch then remove from heat exchange then replace
Mar 06, 2013 | Hayward 250kbtu Ng Pool Heater - Inground
Haward H250 dual therm, heater lights then shuts off after 5 to 10 seconds,even with pressure switch bypassed
it sounds like a flame sensor.its located in lower end of burner box,remove it and clean with fine steel wool or emory cloth.
Sep 02, 2009 | Hayward Pool Products HAYWARD H-Series In...
Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Jun 20, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
H250 cycles on and off pressure is fine. system normal light on. new sand and clear pool. would like to know how to fix problem myself.
I would probably look at your high limit switches first and then at the bypass assembly inside of the header. The bypass controls the heat rise inside the heater. If it is bad, it may heat up too quickly, opening up one of your high limits. That will shut down the heater, once it cools back down, it will start again, and so on and so on.
May 18, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward 250kbtu Ng Pool Heater - Inground Logo
596 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
