Question about Garden
What spark plug should be used for a Murray Quantum XNP 6.5hp mow
What spark plug should be used for a Murray Quantum XNP push mower with a Briggs & Stratton 6.5hp engine?
  • Paul Marks Jul 28, 2012
    howdie champion plugs are good for heat but everything else has to work together fuel air to just like a car
  • 30 Answers
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
How to change a spark plug on a club cadett model # 959435
Hello. Changing the spark plug requires a couple of tools, all available at any auto parts store, and the right replacement plug. Regarding the plug, look in the manual or take the old plug to the auto parts store and have the clerk cross reference for you to be sure you get the same one or a comparable. Look at the links below to learn more about changing spark plugs in lawn mowers than most people know. Have fun with it.
Here is the link to a video to show you the steps. http://www.ehow.com/video_4426873_changing-spark-plugs-lawn-mower.html
http://www.oneprojectcloser.com/how-to-change-spark-plug-in-a-lawnmower-example-briggs-stratton-engines-in-craftsman-and-murray-mowers/
Apr 16, 2010 | Poulan "" Push Mower
Want to remove mowing deck on Murray 42590A model. Looking for owners manual.
The link below will take you to a downloadable PDF fill the has your owners manual.
Good luck, let me know.
Regards,
http://www.murray.com/manuals/index.cfm?rd=1
Oct 12, 2009 | Briggs & Stratton Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
5 HP Briggs and Stratton Engine
use a champion RJ19LM spark plug, you will see that the engine is built by briggs and stratton.hope this helps
Mar 21, 2009 | Garden
Garden Logo
1,322 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
