Question about Canon PowerShot S70 Digital Camera
My lens cover on my canon powershot S70 came off, i need to put it back on. how do i do that?
  • bunyan76 Jun 27, 2009
    its not that kind of lens cover. it's a sliding lens cover for a digital camera, but thank you anyway.
    Problem Solver:
  • 9 Answers
There should be a loop on the side....just run your cord through there and that will hold your lens cover, then you can put it back on when you are done takin pictures
Posted on Jun 26, 2009
I opened the lens cover the lens moved out and the camera went off. Now it won't do anything even when I put a fully charged battery
I think your camera battery is not holding charge, replace it with new one.
Else there may be any of the following fault with your camera.
  • Your Charger may be faulty, try to charge it through USB Cable by connecting it to your system (computer), I case your camera have facility to charge it from computer.
  • ON/OFF switch may be malfunctioning (shorted).
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 01, 2010 | Canon PowerShot S70 Digital Camera
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
Lens do not come out
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 26, 2008 | Canon PowerShot S70 Digital Camera
Canon powershot A560
you need to get camera serviced-usually lens jumps off track or is crooked and gets jamed-did camera get dropped?if older model than 1 yr usually 100-125 to repair-if new model still in warranty they will tell you someone broke it and it's not covered-as a last resort if you are going to toss camera anyway put pressure on lens as you try to zoom in and out or put lens between teeth and try to force back in place
Aug 12, 2008 | Canon PowerShot A560 Digital Camera
Canon s70 won't stay on
I had the same problem a small spring in side the cover came loose luckily I still had warranty left do to mastercard warranty extension which paid the $119.00 that Canon charged to fix it they replaced the whole front.
Aug 11, 2008 | Canon PowerShot S70 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot S70 Digital Camera Logo
225 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
