Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
From customer no"GBW 051809". MY D2 BIGGER TRIPLE EXTREME II power seems to be faulty. It supplies power (blue light) but although discs start to power up do not appear on the desktop when connected by firewire or USB. However using a smaller power supply (for my Big disc triple interface) all works normally. Furthermore when I exchanged the power pack for the newer one supplied with my Big disc extreme triple interface neither of these lacie drives appeared to mount although both initiate disc activity. I seem to have two power packs (both Lacie model no:ACU057A-0512 THAT DO NOT WORK WITH ANY OF MY 4 EXTERNAL LACIE DRIVES. 2 SMALLER (SUNFONE PACKS DO WORK)- PLEASE ADVISE
  • LaCie Master
  • 13,433 Answers
The power adapter must be faulty, replace it with a new one.
http://www.lacie.com/us/products/product.htm?pid=10706
if you are on warranty please contact your dealer or lacie directly for warranty support / replacement.
Thanks,
Ekse
Posted on Jun 26, 2009
I have an old LaCie d2 160GB Hard Drive Extreme with Triple Interface (circa 2005)... I have lost my power cord and I can't seem to be able to find one online to purchase...Does anyone know where I can...
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
I have 3 2TB lacie bigger disk triple interface. I use them to backup my data. Unfortunely I lost 2 power supply so I used one for all. Yesterday I backup up all my data on one disk, I unplug this and...
If the power supply doesn't delivers the correct current the hard disks can't spin fast enough and this is detected as a failure by the pc, which cuts the connection. Hopefully by replacing the source all will go back to normal. Otherwise you will have to crack open the cases, remove the disks and install them directly in a desktop to try to access the data on them.
Dec 14, 2010 | LaCie Bigger Disk Extreme 2000 GB Hard...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
A lacie d2 extreme 250gig triple won't mount anymore
try deleting /uninstalling everything that is not absolutely necessary to free up ram space and see if it improves the situation
Mar 25, 2017 | LaCie d2 Extreme 250GB External with...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
I think that this disk has some bade sector ,try to make a complete scan of tis hard drive by this command "CHKDSK /p /r" to repair this bad sectors and repartitioning this hard drive. some time the reason of this problem is file system of this hard drive is not correct.
Jun 14, 2007 | LaCie Bigger Disk Extreme (300789) 2000 GB
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
234 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
