Question about Philips DVP3146K DVD Player
DVD PLAYER DISC TRAY DOES NOT OPEN
MY PHILIPS DVD PLAYER DVP3146/K DISC TRAY DOES NOT OPEN WHEN PRESSING OPEN/CLOSE BUTTON
  • pri1170 Jun 29, 2009
    Thanks!
    Problem Solver:
  • 6 Answers
Tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
A dvd is from a different region how do i change it to my region
  1. Open the disc tray
  2. Press 1, 1, 1, 1
  3. Press the button for the desired RC (0 = codefree)
  4. Current RC is displayed
  5. Close the disc tray
Dec 08, 2010 | Philips DVD724 DVD Player
My Phillips DVD Player DVP3146 does not read any DVD's as it shows 'NO DISC' Any Solutions???
some dvds are very fussy about which make of disc that will work in them
Jul 05, 2010 | Philips DVP3146K DVD Player
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
How to solve disc region error?
Here's how to make it region free..
1.Keep Tray in eject position
2.Press Setup from remot
3.Go to preference page
4.Press"138931"
5.Using Navigation Key change region code to "0"
6.Press "OK"
7.Regionfree!!
Jay
May 25, 2009 | Televison & Video
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
How to change region codes from only 4 to 2 & 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Philips DVP3146K DVD Player Logo
820 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
