Question about Sony Ericsson K660i Cellular Phone
Phone heating my phone is getting heated up after 5 minutes of continous talking and battery goes down quickly, is there anything to rectify
  • 674 Answers
Try to change you battery, then observe if the same problem ther are sortage or somthing wrong in your cp board.. try chek up...also check the battery terminal
Posted on Jun 26, 2009
Why am I losing battery power so quickly on iPhone 3g so quick? It is Jailbroke but I don't have anything special running in background, and my location settings I only have like 2 that I am allowing, but...
Look for any apps that might be running status updates every few minutes. Such as price checking apps, which updates continously hence using battery and data time.
Mar 01, 2011 | Apple iPhone 3G
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
My battery life is great as long as i dont text or call anyone. My phone can retain power if it is not in use. Everytime i attempt to make a three minute call my phone shuts down after a certain amount of...
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
Take care.
Jul 02, 2010 | LG Vu CU920 Cellular Phone
Phone is heating up very soon
I may know the problem, in my opinion there could be two possible things worng with your "Nokia 5800". One is that your fan(inside the phone) is not working properly. you should get it checked at your local cell phone repair shop. the other less likely problem is that you have a wrong type of battery in your phone. witch can also be fixed at a cell phone repair shop
Jun 30, 2009 | Nokia 5800 XpressMusic Smartphone
How to change alternator in a porsche boxter
2 hours needed to change alternator:
- disconnect battery.
- remove top covers of engine - behind front seats
- remove 4 plastic bolts to remove side cover.
- remove all of the bolts to remove metal cover
- losen belt by putting a 24mm wrench on tensioner and turing CCW. You should also consider changing the belt ($18)
- remove the alternator screw and the flywheel screw beside alternator.
- move the alternator up on the flywheel screw side. If stuck use a hammer and wedge to move it up until it losens.
- remove wire and plug.
Rebuilding the alternator. Only 4 things can be wrong:
1- bearing worn out - turn rotor to test.
2- coils short - smell and check for burning in side.
3- Rectifier - take plastic cap off and test with an ohm meet from the heat sink to each of the 3 diodes, then reverse the testing points. If both resistances are the same on any of the 3 diodes, replace rectifier.
4- If the top 3 are fine, then it is the regulator. This is a hard part to find retail. Ebay and other sellers will try and get over $100 for it. Porche claims they don't sell. I found it a wholesaler, who I begged to sell it to me. Cost C$17. 2 bolts and one screw and 5 minutes later and it was replaced.
To reinstall follow the reverse. Remember the flywheel part of the alternator goes in on the to of the backet. you may have to use a hammer and wedge to get it down. Install the flywheel before it goes all the way down, or it will be difficult to slide in.
Enjoy.
Jan 26, 2009 | 2001 Porsche Boxster
Help !!!!my laptop shuts down
We had some Acers do the exact same thing and we fixed them. I believe it shuts right off as a safety. Usually when the processor gets too hot it powers right off to save the laptop from burning up. First quick fix it to blow out the vents and especially blow out the heat sink vent. Also could be that the heat paste that sits between the CPU and Heat Sink could have dried up and stopped doing it's job to remove heat efficiently from the CPU. Big problem in earlier model Gateway laptops too. This can be fixed by acquiring some paste from a local tech shop and reapplying it. If you feel unsure about it, take it to a tech shop and they can do it quick for cheap if not for free. Keep me posted - Scotty
Apr 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Won't turn on, and heats up quickly when battery is put in.
You need to contact the repairs dept and tell them whats going on. DO NOT LET THEM TRANSFER YOU TO TECH SUPPORT! THey like to do that. Tell them you want someone from there in the corporate office to contact you.
Mar 12, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Battery drains with in 4 hours, cell gets heated during call
Next time you call motorola, ask them to change your phone and not the battery. Your phone has the issue. The battery is being used up due to some error on the phone itself.
Sep 16, 2007 | Motorola Mobility L6 Cellular Phone
Quick Wash cycle restarting
Aestaie, On the quick wash cycle the machine goes through a heated rinse at 160 degrees. I think what's happening here is that the board checks the thermistor and is finding that the water is not hot enough and say's, hey, I need more time to heat this water and resets itself. The element in the dishwasher will only heat the water 1 degree every 3 to 5 minutes. So after the initial wash, there is a 2 minute drain, it fills again and there is the heated rinse. If the water is 120 and the final rinse needs to be 160, we have some heating to do here. Therefore the reset. Sounds like the dishwasher is working OK, Catriver..post back
Apr 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Sony Ericsson K660i Cellular Phone Logo
55 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
