Machine is on currently and has reached the spin part of the cycle still with 45 minutes to go on the digitial display.???? 2 hours and 29 minutes is too long, my estimate for a standard wash would be half that time..Machine is on currently and has reached the spin part of the cycle still with 45 minutes to go on the digitial display.???? 2 hours and 29 minutes is too long, my estimate for a standard wash would be half that time..
You can't post conmments that contain an email address.
Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
I had to ask my doctor about that for my daughter and she told me to line dry. inside if possible because outside would only put pollen and other spores on it.
Maybe its build up inside the dishwasher. A solution to this is to run one of the avaliable products for cleaning out the lime/scale/crud inside. Just because it looks clean doesn't mean that the hidden pump and lines aren't either partially clogged.or almost blocked. Is the hot water at 140 degrees? If not then the element inside may be attempting to heat the water to that minimum setting, If this doesn't help then I'd look at replacing the timer.
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry
button.
• For most even drying , make sure all articles in the
clothes load are similar in material and thickness.
• Do not overload dryer by stuffing too many articles
into drum. Items must be able to tumble freely
• If you open door and remove load before dryer has
finished its cycle, remember to press the
Start/Pause button.
• By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less"
• Your dryer can handle a load of up to 9 lbs.
(4 kg) dry weight of articles.
• When drying cycle is completed, [Cd] (Cool Down)
is displayed on the Multi display.
• Cool Down is set automatically when the drying
cycle is complete.
• If clothes are not removed promptly when the
drying cycle ends, wrinkles can form.
• The Cool Down feature periodically tumbles,
rearranges and fluffs the load to avoid wrinkles for
up to 4 hours.
• The message [Cd] will continue to display until the
clothes are removed or the Start/Pause button is
pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment
Thank You
Joe
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button. Wait for door to lock.
Press the START button two more times--this will enable the tub to tumble. After 3 hours--turn "off" the washer. Turn the washer back "on". Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub. This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
I managed to solve the problem the following way:
I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
