Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a raypak 2100 digital - it fires up then the fire shuts down and codes such as RV1 and RV0 show up - it continues to try and reignite but cant
    Top Expert:
  • Raypak Master
  • 8,502 Answers
Check gas pressure then flame sensor
Posted on Dec 02, 2017
2 Suggested Answers
  • 5370 Answers
SOURCE: I have a raypak 2100
The water flow to the heater is obstructed causing the heater to shut off due to over heating.-------For code RV1 troubleshooting.Click the link below:--- http://technoanswers.blogspot.com/2011/06/code-rv1-on-raypak-2100-digital-pool.html -------- This should help.Thanks.Helpmech.
Posted on Jun 06, 2011
Raypac 2100 rvo error code
check high limits or fusible link if quit while running could have overheated
Aug 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
The pilot will light but the burnner won't ignite. A pool guy said to turn the theromstate control real slow to a higher tempature and then the burnner will ignite. That worked a few times but now that has...
More likly you have a dirty filter. Or a plug in a line. Test this by jumping your pressure switch. You can also check thr roll out switch the wire that rung along the fire wall just above the burners. It will have a black cover about two inches long on it that has a switch that is cased in wax if the fire rolls out the front of the cabnet the wax melts and shuts the heater down. Check this by jumping also. I hope this helps.
Sep 02, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
The raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
Apr 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Oct 24, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
141 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
