Question about Samsung HLP4663W 46" Rear Projection HDTV
Lamps TV went black, still had sound. So thought it was the bulb. Ordered a new bulb, installed it and it worked for a hour then went black. Called samsung tech support and they went through the steps of unplugging the tv and plugging it back and the lamp light blinked on in front. So it's got to be order another lamp, this one was bad. But the light comes on when i look at it from the back and so does the old lamp. Neither looks blown, but the old one was 3 years old.
  • 143 Answers
Color wheel brakes then causes this same affects check your wheel
Posted on Nov 30, 2007
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
Feb 25, 2012 | Vizio 42 in. LCD TV
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like, to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
I have a samsung tv, HLT61765X/XAA. the picture has gone really dark. Could it be the bulb?
yeah this sounds like a bulb burning out they are made to last 6000-8000 life hours I found the lamp you need just in case
Oct 26, 2010 | Samsung HLT6176S Television
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Sounds like the lamp to me. The projection lamps get hotter as they age and the TVs have a sensor to monitor the temp and shutdown the TV if it get too high
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to buy just the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Jan 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Sony 60' projection model # kdfe60a20
I finally wet out and bought the tv repair manual. Thought the problem had to be more than the bulb because i was losing sound too. Everything in hte repair manual brought me to the bulb or the ballast. I ordered a replacemant bulb. I spent about 150, which included overnight shipping. I replaced the bulb just before Thanksgiving and haven't had any problems as of yet....
Nov 06, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
93 people viewed this question
Jerry Greenberg
Jerry Greenberg
