Question about Car Audio & Video
Car amp my protect light stays on even though everything is hooked up right.
  • 3 more comments
  • DuB2 Feb 09, 2008
    I have a compasador hooked up to my amp. when I turn on my car the protect light stays on untill I shut my car off. The compasador powers down an then the light turns green on the amp.
  • realtalk415 Apr 06, 2008
    amp was working fine, hooked up new speakers and now the protect light's on and no sound from the new speakers, if i disconnect the speakers and the RCA and if the light is no longer on then does that mean everything is all good?
  • Reaper414 Jun 22, 2008
    I have the same problem, my protect light flashes on and off, works some of the time and then doesn't. I just checked the voltage and it was reading 12v+. Now according to a post that means it's deffective, any way to fix this?
  • vamwolf Jul 09, 2008
    Alright so I have a similar problem. The amp was working fine in my car and just stopped one day and went into protect mode. I checked all the wriing and everything looked fine. So I figured the amp must have blown or something. I bought a new one and it does the same exact thing. I can connect everything to it and it seems fine but the second I hook up the rca cables from the deck it goes into protect mode. Also the green light never comes on.
  • Anonymous Mar 20, 2014
    Everything is hooked up correctly but as soon as I turn it on the amp goes into protect
  • 631 Answers
The most common reason for this is shorted output transistors. To confirm that the problem is in the amplifier, disconnect all speaker wires and the RCA cables. If the amp still goes into protection, check the DC voltage across the B+ and ground terminals. It should not drop below 11 volts. Also check the remote voltage.
If the amp continues to go into protect with no external connections (other than B+, remote and ground) and the voltage remaiins above 11v, the amp is defective.
Posted on Nov 06, 2007
Pbabin's solution is correct for most amplifiers, but isn't exactly the case for this particular amplifier. Infinity has been a good name brand, making quality stuff, and was the 'upper line' of JBL made by parent company harman. This series of amps, however is junk compared to previous series, and does not even come close to the quality of even a JBL amp. I think the company might have been sold, and the buyer used the nice marque to sell cheaply built amps. I have been repairing amps for years, and I have 2 of these sitting here that check out fine across the board, but for some reason the protection circuit is still shutting down the amp. The protection circuit is supposed to protect the circuitry when a fault occurs, such as touching the speaker wires, or grounding out. This series of amps seems to have a fatal flaw, in that once the protection is triggered, it never releases, even though the circuitry of the amp is perfectly fine and would operate as it should. So with that problem, on top of the fact that the protection trips much easier than it should, means there are a whole lot of these amps out there that are unusable. I was able to bypass this protection circuit on one amp, but the time and effort involved in doing that are not worth it to save an amp of this quality. I was always a fan of infinity stuff, but it appears they have either gone down hill, or this series of amps in particular suffers from major design flaws. I cannot speak of the company as a whole, as I have not messed with any of their higher series amps that are this new. This model in particular seems to be the worst of this troubled series. If there are any other techs out there that can devise a way to reset this protection circuit, I'm all ears, but it's a custom IC that controls this function, and I can't find data on this chip to know what pins do what. If you can find info on this chip, you could put a momentary switch on the side of the amp to reset the circuit, and this would allow continued use of these amps.
Posted on Aug 12, 2008
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
I have a lightning audio amp a B4.320.4 and Protect Lght stays on
the amp probably got to hot and had a thermal shut down witch will have to be fixed by a professional.
Mar 06, 2010 | Lightning Audio Car Audio & Video
Um the power light will flash then the protl. light will flash its all hooked up right but weird sounds coming out my subs.
Disconnect subs from output of amplifier and then turn on car and radio. Does amp stay on or go into protect? If it stays on then there is something wrong with the subs or how they are wired (series, parallel ) to the box and amp. If it still goes into protect then something internal with amp.
Feb 23, 2010 | Concept Car Audio & Video
Protection light stays on even when everything is disconnected.the output transistors are turning red hot instantly and it has a 20 amp draw on it.while it is hooked up to a power supply with no sound...
there is a short somewhere one your board that is putting all the load on your output transistors follow the traces on the board both ways to find the short
Jul 05, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Protection light
take the amp out and hookit up to the car battery and let it charge then unplug it do this a couple of times then rehook it to the cars audio system it sounds like your amp may be locked..
also check your speaker wires from amp to speaker box then from the back of the box to the speaker inside the box you may have a short..
thats where i would start.. hope this helps
Dec 19, 2008 | Car Audio & Video
Protection light
Hello. First, disconnect all of the speakers the amp is driving and the rca inputs while the amp is off. Now power on the remote. If the prot. light still stays on you will need to varify that the voltage across the ground and b+ terminals is a minimum of 12 volts. If this is true than your amp may be damaged due to shorted parts. Otherwise, try to repower the amp while a speaker is connected and if it is O.K. than there may be a problem with the RCA ground in the head unit or the amplifier. We service these amps at Sound Repair 321-690-0808.
Jul 10, 2008 | Kole audio Q1-3000D Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
Cadence z1200 stays in Safe Mode!
If the subs are rmoved from the amp (wiring), does the amp still go into protection without them hooked up? If no, shorted sub, if it still des, unplug RCA's, does it still go into protection? Also check voltage. Make SURE you have greater than 12 volts AT THE AMP using amps ground to check the power AND remote wires. Hit me back wth an update.Those amps rock.
Larry T
Winona Lake, IN
Sep 17, 2006 | Cadence Z8000 Car Audio Amplifier
Car Audio & Video Logo
675 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
