Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
I have a Hoover Anniversary Special Edition and the Power Brush stays in the Off position. What am I doing wrong. It will not go into the "on" position. I have changed the floor surfaces and still it does not come on?
  • 10,515 Answers
Have you checked the Brush On/Off switch?
If you find that switch is not working :-
Order it at :-
http://www.govacuum.com/hoovwinonswi.html
Also, Try to adjust the position of the brush. Sometimes, it might work.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 26, 2009
My hoover F6207-900 center spin brush won't stay in why?
Hoover SteamVac brushes not spinning
This video might help ... it is a related model.
The usual problem with these brushes is that they stop spinning ... not that they will not stay in.
As shown in the video ... they just clip back in by pressing the whole unit in to the housing. The protruding square pin in the middle does need to line up with the housing drive ... or it will not press in. The two alignment posts need to be in the correct position also. The brushes need to be hand wriggled to help alignment so the square peg will enter the square drive hole.
If you are successfully getting the brush unit all the way in ... and it does turn when the unit is turned on ... all I can think of is that the alignment posts have somehow broken...
Mar 15, 2018 | Hoover Vacuums
I am trying to replace the brush housing on my hoover uh70210 windtunnel paws edition I was able to do everything except attaching the hose Any suggestion on how to do this It is much harder than it looks
I got a Video on how to replace the Brush and Belt etc.
Check it out
Also I cannot find out a way to re attach the hose back in the Hoover. Have you check the Instructions/Manual on that to get it all complete?
Apr 10, 2014 | Vacuums
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
I have a hoover f5914-900 steam vac.. and I was wondering if there's a way to take apart the spin brushes to get them cleaned out well. I loaned it to family, and the brushes came back extremely soiled and...
The brush block may be removed from the base for rinsing.
Yes, you can CAREFULLY disassemble the brush block assembly by releasing each of three latches that hold each of the clear gear covers to the main block. A small screwdriver is used to GENTLY lift each tab, one at a time. Pay attention to what position the special gear is at that has the drive pin (1/4 inch square drive) for correct reassembly.
Here is the link to the User Manual that shows how to remove the brushes from the base.
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Feb 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover U5491900 Anniversary Windtunnel will not pick up very well, there is good suction when I use the attachments, but when I use it on the floor it won't pick up much, what is wrong with it and how...
The reason why it is not picking up well is because the belt is worn or stretched and it can't turn the brush (which picks up debris) against the resistance of the carpet. Here is the belt you need:
Hoover U5491900 Belt
Jan 20, 2010 | Hoover U5491-900 Bagged Upright Vacuum
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My brushes don't rotate on the on position. I have a SteamVac V2.
Do you hear the motor for the beater bar brush running? If so, you'll probably need to replace the brush drive belt.. If not.. you may have a broken wire suppling power to the brush motor.. or the switch is bad.. Hope that helps..
Aug 30, 2008 | Hoover Vacuums
Hoover Vacuum correction
I don't know what is your experience with wire's soldering, but you should remove the insulation from the damaged wire and solder the disconnected edges. Then wrap an insulation band on the repaired wire first and then on all the other wires. Be aware power cable is disconnected !!!! If you can't do it by yourself - repair cost for it should be very cheap. Good luck !!
Jun 28, 2006 | Hoover S3614 Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
