Question about Victory Freezers
My freezer will not hold temperature. Only a year
My freezer will not hold temperature. Victory V-2 Freezer purchased from private person four months ago. Never used, about a year old. Will not hold temperature. Runs constantly. Checked freon- OK. Ambiant temperature around eighty degrees. Plenty of air flow.
  • Victory Master
  • 1,253 Answers
If what you say is accurate, I would look at either a weak compressor or and issue with the expansion device. (Cap tube, TXV)
What are your pressures and what freon are you using? Does the door(s) seal tight?
Posted on Jun 28, 2009
What is the suitable temperature for 3 star freezer in uk summer?
3 star freezers are not storage freezers and will maintain frozen food for a short time only, They should reach -18c when closed but may come up in temperature quite rapidly when the door is opened. They are usually found as the cooling evaporator in fridges with freezer boxes in. Four star freezers are dedicated freezer storage space and will keep frozen food at the right temperature for some months.
May 19, 2012 | LEC Freezers
Purchased ColdTechCommercial Freezer CFD-3F from private seller. Freezer was used for 9 months then sat in a garage for almost two years. Freezer turns on and runs, but doesn't cool at all- in fact,...
Hose underneath is probably for condensation and defrost water. If the compressor is not coming on, there is a good chance it is the thermostat. There is always the possibility that there is a refrigerant leak and it leaked down over the 2 year period. This is where I would start.
Jul 08, 2017 | Coldtech 72 cu. ft. / 2039 liter Upright...
Where to buy compression online
http://www.victory-refrig.com/index.htm
Check out their web site. Has parts lists.
You may not need to buy directly from them. Most of those compressors can be purchased from local HVAC supply houses that sell to the public. Get model and serial and brand off of the compressor and try W.W. Grainger. They do sell some compressors. Also, try Rick, at Restaurant Parts and More. He will need model and serial of the unit, and possibly the compressor. The more info the better. His number is 1-888-814-1110.Talk to Rick only.
Let me know if I can be of any future help.
Dec 29, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
My GE upright freezer constantly beeps!
It sounds like this is a a non DIY issue. there is really not much you personally can do.
Contact an authorized servicer fir best results
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 13, 2017 | GE Freezers
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Normal operating pressures
Normal operating pressures will change as the freezer reaches the selected temperatures on the inside. Normals of minus 14 degrees on the inside would be around minus 4 psi on the suction and 150 pis on discharge. Now checking the pressure will require a set of guages that have been purged with the same freon before connecting with the suction line on freezer. If not purged the suction line will draw outside air into the system and cause freezing of air and moisture inside the capillary tube rendering the freezer inoperative, Hope this helps, Sea Breeze
Nov 01, 2007 | Freezers
Freezers Logo
349 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
christian nielsen
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
