Question about Pioneer VSX-1018AH-K Receiver
No hdmi audio
I have hdmi cables from dvd and satellite hooked to my pioneer 1018ah-k outputting to a samsung hdtv via hdmi cables. i get video to the tv, but no audio. When i go to the menu"receiver" "audoi functions" and scroll through, it goes from "sacd" to "mcacc" without going to "hdmi", which i assume is where i make the adjustment to "through". Any suggestions?
Thanks for the help
  • 34 Answers
Some receivers need extra audio cable beside hdmi ............dont ask me why
use optical or coaxial cable for digital audio and see if it works
let me know
Posted on Jun 26, 2009
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
PIONEER VSX-1018AH NO SOUND OUTPUT
If this is a new hookup be sure this amp doesn't have pre-out/main-in jacks that may need to be bypassed. Otherwise, maybe look to see if any tape deck buttons are pushed. Good luck.
Nov 21, 2008 | Pioneer VSX-1018AH-K Receiver
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Pioneer VSX-1018AH-K Receiver Logo
275 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
