Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
A
Anonymous Posted on Jun 11, 2014
How do I get worn off model number for ge side by side refrigerator
My ge monogram oven model number ZET1PH1SS, barely 2 years old, oven light will not turn off
Check that whatever switches the light on and off is making good contact. My GE fridge has a bottle cap glued to the inside of the door, crude but it works. Some are magnetically operated, so you could test with a rare earth magnet.
For a mere $73 you can purchase a new switch.
ZET1PH1SS - Appliance Parts HQ
www.appliancepartshq.ca > lookup
Search by Keyword(s):. Diagram for ZET1PH1SS ... 55, WG02L07803, Badge Monogram Small No Pin, $150.44 ... 132, WG02L03187, G.e. Range Door Gasket, $84.82 ... 608, WG03F03565, G.e. Refrigerator Freezer Light Switch, $73.40
Dec 19, 2020 • GE Ovens
1helpful
2answers
What is the part number for a replacement lower heating (baking) element in a GE JBS07V6WW oven?
The parts diagram for the JBS07V6 is available here: https://www.appliancepartspros.com/parts-for-ge-jbs07v6.html . The last two characters indicate the color of the range. The bake element (lower) is part 650 on the body cavity parts diagram. This gives the current part number as AP2031061 or WB44X10009 . See https://www.appliancepartspros.com/ge-bake-element-wb44x10009-ap2031061.html . This is a replacement part number and the previous part numbers are listed on the left hand side of the page (second link).
I hope this helps.
Apr 26, 2020 • GE Ovens
Ge JTP 95 error code f11
Remove the connector that extends from the touch pad to the control board, sometimes there will be a plastic "locking bar" that needs to be loosened before the cable can be removed... Squeeze the ears on either side toward the middle and gently lift the locking bar up... If there is no locker, simply "wiggling" the connector softly while pulling should release it.
Your model # is incomplete Help Me Find My Model Number RepairClinic com
Jul 10, 2016 • GE Ovens
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
1helpful
5answers
Number and temperature decals washed off my stove. I can't even remember right now if its a hotpoint or a frigidaire~ that washed away too!
you can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
1helpful
2answers
General Electric JKP45 Double Oven
Don't know why repairman couldn't order parts you have your model #. The model # is the JKP45WV1WW, The part # is WB26K5030 for the lock motor.
2answers
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Top Hotpoint Ovens Experts
Mike Cairns
Mike Cairns
paul fairbanks
Larry Ng
Larry Ng
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
