Question about Panasonic DMC-TZ5 Digital Camera
Memory card stuck in camera
The memory card is stuck in the camera, and wont come out..what shall i do ?
    Problem Solver:
  • 13 Answers
Normally the card is spring loaded, so when you press down on it, it will pop out. If the card is stuck solid, don't try and force it out. Be gentle and try coax it out with some needle nose pliers.
If you feel the plastic flexing or if anything may break, it may a case of dissembling the camera.
Posted on Jun 26, 2009
Hi why my omnia 1900 cannot take picture? its appear only loading?
Check the available free memory on phone & memory card. If the phone memory is almost full then your camera will not work. Check the option of saving the photo files in camera menu, which has to be memory card & not phone. Any photo files on phone shall be transferred to memory card. Delete unwanted messages to free up more memory. Please get back to me if the there is sufficient free memory in phone & still the problem remains.
Sep 25, 2011 | Samsung SGH-i900 Omnia Unlocked Cellular...
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
Whenever I try to view newly taken photos, it loads for a really long time and the light flashes oranges and reds. So I turn it off and then can't turn it back on until I have opened the bit where the...
Hi!
Posible solutions:
1. Try to format the memory in the Camera and try if it works ok.
2. If you have problems formatting with your camera download the "HP USB Disk Storage Format Tool" that will repartition and format your memory card.
3. If none of these steps work for you maybe your memory card is broken. Try Another one on the camera.
Hope this helps!
Mar 05, 2011 | FUJIFILM FinePix S1600 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
No image shown
If you took the pictures, and stored them on the camera's internal memory, then put in a memory card, it will read from the card and you wont be able to see the photos that are actually stuck on the camera. Try removing the SD card, then check for your photos.
Conversely, if you took the photos when the card was in, and then removed the card, the photos wont be stored on the camera, so you should look for the card.
Jun 23, 2009 | Polaroid i634 Digital Camera
Camera wont work says the card is locked
Take out the memory card and on one of the sides there is a little slider and push it in the opposite posistion and it will be unlocked and shall work.
May 21, 2009 | Samsung NV3 Digital Camera
Memory stick locked
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Jan 06, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Formatting memory card
Formatting Memory Card
A new SD card shall be firstly formatted before use.
a.) Select (Format) to enter into property list.
b.) Select “NO” to cancel the formatting. Select “YES” and press (OK) to execute the
formatting.
c.) All the contents in the memory will be cleared after formatting.
About Memory Card
The external card supported by this camera is SD card.
To use a new SD card, you have to format it firstly.
Maloperation may cause damage to or deletion of the data recorded.
The loss arising from deletion of recorded data will not be the manufacturer's
responsibility.
Electrical interference, static electricity and failure of video camera or memory card
might damage the data in the card. Therefore, it is suggested to transfer the data to
your computer timely.
Never take out the memory card or turn off the video camera when reading or writing
the data.
Never put the card under high temperature or high humidity.
Never modify or tear down it.
Cheers.
Dec 03, 2007 | Mustek DV520T Digital Camera
Panasonic DMC-TZ5 Digital Camera Logo
314 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
