Question about Sony Playstation 3 (PS3) Console
PS3 - screen flickering
I have a LG FULL HDTV (42LG70YD) and I get the same snowy flickery **** every few seconds, I went and exchanged my PS3 and it still does the same thing. I have used 2 separate HDMI cables and still nothing.
I going to try and find someone who has that "Monster HDMI cable (Monster 1000HD)", it's around $349.00 at Harvey Norman but everyones telling me its the best because the HDMI cable can pump more information through it - from the PS3 to the TV and vice versa.
It can't be the TV because its just new and also I got that promotional 26 inch TV from LG and I first hooked up my PS3 to that TV and straight away I was able to play at 1080p output. Now I can only play at 1080i.
I think Sony Computer Entertainment should bring out a new firmware update for the PS3 that is dedicated to only fixing this issue.
SOURCE: Playstation 3 Flickers when set to 1080P
I did some further research. I updated my firmware for TV(samsung) to the latest. This did not resolve the problem. Then I changed the hdmi ports. what I found is that the problem(ofcourse only with 1080p) is seen in the first 3 hdmi ports on tv, BUT NOT at HDMI 4 port. That may be our TEMPORARY SOLUTION. but not a final solution.
In samsung LNxxA650 series, HDMI 4 is at the side, not in the same zone as other 3 in the back. so, it's hardware implement may be little different.
So, does it mean it's been all TV's fault? no, not necessarily. The ports 1,2,3 are working good with blue-ray disk videos with 1080p. How is that possible? So, well, for one, I think PS3 itself could use different ways (integrated chip vs embedded firmware OS ) for launching xmb vs running blue-ray videos. If it is a handshake issue, then PS3 has to resolve; I will also call samsung and launch an investigation. For them, All ports should behave the same. period.
Suggestion: As for other TV brands, try with other ports and check. Otherwise, update firmware/call TV technician. please launch complaints at TV so, that they realize that they need work together to with SONY folks to get this resolved.
Posted on Jan 11, 2009
SOURCE: PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
Posted on May 14, 2009
SOURCE: cannot output 1080p with a full hd 1080p hdtv
You have a degree in computers & you don't know that both your tv & ps3 have to be on & running before you plug in any hdmi? lol. Hope you didn't over pay for the degree like you did for the cord
Posted on May 20, 2009
  • 44 Answers
SOURCE: No signal when outputting 1080p on ps3
put your ps3 in standby (solid red light), and then hold the power button until it beeps a second time. then the picture should come up.
Posted on Jun 23, 2009
  • 943 Answers
SOURCE: I have 2 ps3 consoles one new slim model other is
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Posted on Mar 08, 2010
LG LED TV, model #50LB5900-UV has flickering screen. Need advice on part replacements.
It is a very common problem for LG LED TV, the problem is defective back lights LED strip. You need to open the display panel, find the burn out strips & replace it (them).
Jul 31, 2017 | LG Televison & Video
I've had a slim PS3 for a few years now and just today, shortly after a usual system update, it started flickering constantly. Not the whole screen is affected but only some especially bright colors, e.g....
First, back up all of your saved data to an external source. Then, to a factory default reset of the system and redownload the update. Check to see if problem persists, if not, copy back all of your saved data and you should be good to go.
Aug 09, 2013 | Sony Playstation 3 (PS3) Console
Lg 32ld450 backlight flickering
Check its back light inverter board.
Jul 13, 2013 | LG 32LD450 32 In. LCD HDTV
Flickering problem with our LG Plasma 60 ps4 when connected to hd
I had a problem similar to that. I couldn't get a full picture from my laptop or desktop. I went into the menu and hit the adjust screen. Now I have a full picture on my 50" plasma tv.
Jul 23, 2010 | LG 60PS60 60 in. Plasma HDTV
Flickering in the main PS3 screen with 1080p resolution
1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
May 02, 2010 | Sony Playstation 3 (PS3) Console
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like, to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
460 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
