Question about Car Audio & Video
Need to know which colour cables to which pin no's on c3 connector to join cdca05 stacker to seville head unit, both are blaupunkt. previous owner pulled pins out of plug
  • 10,515 Answers
Blue/Red stripe = Permanent +12V (Blaupunkt's Yellow)
Yellow/Blue stripe = Ignition (Blaupunkt's Red)
Purple = Illumination (Blaupunkt's Orange)
Blue/White stripe = Auto Antenna (Blaupunkt's Blue)
Black = Ground (Blaupunkt's Black)
If you have an amplifier, Blaupunkt's switched 12V Remote wire is found in the Line Out harness, the Blue/Yellow stripe wire.
Hope i helped you.
Thanks for using 'Fixya'.
Posted on Jun 26, 2009
Left speaker in my 1998 chevy s10 fades out then dies
What have you tried?
Is this an aftermarket sound system?
It could be a fault in the head unit, the cables or the speaker itself.
Assuming that its and aftermarket head unit using original wires this is what I would do:
Remove the head unit to gain access the wiring behind.
Most units have the wiring colour coded and a generally in pairs for +ve and -ve, some even have them label LR (Left Rear) RR (Right Rear) LF (Left Front) RF (Right Front).
The wires are commonly joined to the existing speaker wires by insulated electrical "connectors" that simply pull apart, though only pull on the connector NOT the wire.
Half-way jobs are just the bared wired "twisted" around the joining wire and wrapped in electrical tape.
Ensure all the connectors are still in tact and
Test after removing each pair of speaker wire to which speaker is disconnected.
When you determine which wire is for which, switch the non-working left speaker over with a working one and test to see if the speaker still fades.
1. If it does not fade then your problem is the head unit - I would replace it.
2. If it does then the problem is in the speaker or the wiring.
Remove the speaker and swap with one of your working speakers.
A. If it still fades then the problem is in your wiring and you will need to run new wires.
B. If it does not fade then the problem is simply your speaker.
Hope that helps.
Apr 09, 2014 | Pyle Car Audio & Video
I am getting "cd error" when put my disc into
  • Unfortunately it may be time for a new deck (stacker). You can try pulling the deck head out and removing the power for 10 minutes or so and re-connecting the power and this sometimes will buy you some time. Now a while back Blaupunkt was offering a free replacement for some of these units so it might be worth contacting the Blaupunkt web page for your country (where ever that be) http://www.blaupunkt.de/index.php?id=537&L=1 and see if the are still honoring warranties on them. In the end it may very well be time to replace your unit. This is a very common problem for Blaupunkt.
Regards, Tony
May 11, 2011 | Blaupunkt Car Audio & Video
Pioneer CDX-P670 Wiring / Power
hi according to the manual the two pin connector is for the power and the pin nearest the square control plug is ground, the other pin is +12, have tried this with mine and it works
Nov 26, 2009 | Pioneer CDX-P670 6-Disc CD Changer
PEUGEOT 306 L REG 14.0 XL WIRING TO FIT A STEREO AS PREVIOUS OWNER HAS CHOPPED & CHANGED THE CONNECTORS & WIRING I HAVE THE COLOURS INDICATED ON A STICKER FOR THE STEREO IM TRYINYG TO FIT ON A
need to no what colours cables u have would be easy to talk u through it on the phone.but here we go anyway red is power and yellow is constant power (for memorey ie radio stations )back is earth. blue is remote for an amp to turn it on vier the head unit.and all the rest are speaker cables ie two greens two purple two black and two grey colour.but your peugeot electrial harness mite be different colours though thats why its better to talk on the phone about it let me no an illl let u have me number hope this helps.
May 22, 2009 | Kenwood Car Audio & Video
Car stereo wiring color codes for Proton Satria
want to know wiring colour codecs standard
Mar 26, 2009 | Car Audio & Video
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Require the pinout for a 8 pin plug
I don't really know. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 24, 2017 | Clarion Car Audio & Video
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
