Question about Yamaha HTR-6160 Receiver
NO SOUND WHEN RUNNING THRU BLUE RAY OR HD CABLE BOX THE CENTER CHANNEL SOUND COMES AND GOES . NO MATTER WHAT SOUND FIELD EXCEPT ENHANCED 7 CHANNEL THEN OK. I WENT FROM HDMI TO OPTICAL THINKING MAY FIX PROBLEM BUT DID NOT.IF INCREASE VOLUME SOUND COMES BACK BUT NOT FOR LONG
  • 30 Answers
Try cleaning the eye with rubbing alcohol and a "Q" tip.
Posted on Jun 27, 2009
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Tv screen goes black after 15-20 seconds
It's not the TV from what I can tell. I would start complaining about it and say you want a brand new box. Not used. They tend to give out boxes from people who previously had them and either didn't pay their bill or moved and clean them up.
Dec 30, 2012 | Televison & Video
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Jan 21, 2010 | Vizio VX37L Television
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
Jan 16, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Never hooked up the HD
Have you tried selecting a different input( do you have the remote?), if so have you set your input to accept HD input ( you access this thru your 'Menu" button on your remote). I run my HD input from my game console (X-Box 360) and have to select HDTV input channel (there are 2 of them along with 2 cable inputs), and have not had a problem with this at all. good luck.
Mar 18, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Nov 27, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
Yamaha HTR-6160 Receiver Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
