this problem occurs when phone internal memory is low or corrupted, first do a contacts backup and complete back up on storage card, then do a factory reset from phone setting, and restore contacts fro card. if problem still persists do a online software update by downloading nokia software updater from nokia we site
You will need to see if the service provider has blocked your calls with a reason and so call up the tool free to confirm .
If the SIM is tested also on another set it can be confirmed.
if so the software of the phone must be reinstalled.
Programming is done on M7310, M7324 and T7316 sets. To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344. The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming. At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow) The display should sat LINE ACCESS Press the show key (top right arrow) . The display should say LINE ASSIGNMENT. Press the show key (top right arrow) . The display ask for a line number. press list The display should say line 001: appear & ring press the Chng key till it says appear only press next key (lower right arrow) The display should say line 002: appear & ring repeat the procedure the same as line 001 for the remaining ringing lines
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
