Question about Garden
The trimmer head of my Poulan Weedeater RTE 115 is stuck, it will not unscrew so that we can change the trimmer line. Any suggestions?
  • Anonymous Mar 24, 2014
    I tried to unscrew head,tried to Locate the small hole...
  • 59 Answers
It has left hand treads
Posted on Jun 27, 2009
Weedeater wt3100 carb and fuel line diagram
motor will start after several pulls but will only run for about 10 seconds,
Nov 01, 2012 | Poulan Pro 952711635 String Trimmer Line...
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have read the instructions on rethreading the twist and edge rte 115 but it still doesn't make any sense. Do you have instructions with pictures?
Usually, the only instructions with pictures for repairs like this are on a You Tube video if you are lucky. They may be diagrams with instructions available though. This problem is common with these units and I just recommend taking the old head off and getting a Universal type string head at the home improvement store as a replacement. You can look here if you feel a manual with diagrams can help. This is closest thing to your model I could find. See page 7.
http://dl.owneriq.net/c/cc3d8bf0-cc46-418b-bed8-e13da682e377.pdf
Oct 30, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Oct 25, 2009 | Electric Garden
Do not know how to correctly string so string will come out as it is supposed to on my poulan pro weedeater, do not have directions
There are five ways to change trimmer line depending upon the style of trimmer head on your unit.
The first style has a locking tab on the side of the trimmer head that must be depressed while the lock ring is turned counter-clockwise. This will remove the cover and give access to the spool which can then be pulled out, rewound with the line (winding in the direction of the arrows on the spool), and re-installed.
The second style requires lining up the marks on the bottom of the spool tap/button assembly and firmly pulling straight out on the tap button. This pulls the spool assembly out so it can be re-wound and inserted back into the hub assembly.
The third style requires pushing in and down on the two locking tabs on the side of the trimmer head. This will remove the cover and give you access to the spool.
The fourth style of trimmer head is the Centrex. Remove the cap on the bottom of the head by unscrewing it. Remove the guide ring and remove the spool from the unit. Cut a 25ft length of line and insert one end into the center cavity of the empty spool. Feed the line into the spool, leaving 4-6 inches unwound from the center of the spool. Reinstall the spool, guide and cap, making sure the notch in the guide is facing away from the spool and the line is in the notch.
The fifth style is the fixed line cutting head. This style cutting head uses a pre-cut piece of cutting line. After removing the worn line from the cutting head, insert the precut piece into the positioning tunnel leaving an equal amount out each side of the tunnel. The ends of the line can then be inserted through the exit tunnels.
Oct 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I can't seem to find the replacement spools of line for my Weed Eater Model number RTE 115 C. Do you have any suggestions?
lowes supply carrys a good variable supply of replacement lines different thicknesses etc....hope this helps..chris
May 13, 2009 | Garden
Weedeater quits working/button no longer activates weedeater
try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
Replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear fitzknight: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Poulan 12" Electric Twist N Edge Plus...
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
