Question about Panasonic KX-T7730 Corded Phone
I have an 824 and i am using the kxt7730. when I answer a call, the caller doesnt hear me for the first 2 seconds then i have to repeat my self. we dont have a DISA or Voice mail or Auto Attendant. i have changed the phone, but this has not made any difference. i have also reset the my handset by pressing program #* store and program.
  • 2 more comments
  • zak7 Jun 26, 2009
    its only my phone, the fault is on all the lines but only my extension.
    if i enter program code 999 and clear the extension data, will this be the same as restting the system? if i was to reset the system, the programming will be a long process.
  • zak7 Jun 26, 2009
    i tried 790, this didnt make a difference
    this will mean i will lose one extension. will the reset not work
  • zak7 Jun 26, 2009
    i will try to change ports, and see what happens. thanks
  • Carl Navarro
    Carl Navarro May 11, 2010
    Is this only on your phone? Did you swap lines 1&2 on the phone systrem? Try to determine if you have a bad port on the phone sytsem, or bad line coming into the phone system, or bad extension.
  • Panasonic Master
  • 2,460 Answers
Dialing 790 on the intercom resets the extension. If you move your phone to another port on the system does it work? If it does, do that and swap directory numbers in programming.
Posted on Jun 26, 2009
  • Carl Navarro
    Carl Navarro Jun 26, 2009
    it's only a problem if you don't have any spares. In the course of swapping, you may find that a single line phone works on it, a fax will probably work, vm may work, and it may be something with the line. The idea is to just move the port for your phone and see if it fixes you and transfers the problem to someone else.
    You could initialize the system and reprogram from scratch if that's what you want to do, but it wastes a lot of time if it wasn't the fix.
Resetting my jabra extreme 2
If your Jabra Extreme2 Voice guidance is not turned on - i.e. you only hear beeps when you power on or a call comes in...
Cause: powered on or off with answer button depressed
Solution:
1) Power off
2) Hold down answer button (the one that lights up Jabra)
3) Power on
4) Release answer button
You may need to repeat.
Jan 24, 2013 | Jabra Extreme2 Bluetooth Headset
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Dec 07, 2009 | Doro 830R Cordless Phone
Call Waiting
When 2-nd call is ringing (you can hear ringing in the hand set while talking) word "Recall" appears in display. Press the button below the word "Recall" (top left side, dark grey button) and then press number "2". You will get connected with second caller while the first is put on hold. When finished with second caller, press again word "Recall" and then number "1" and you get connected back to first caller.
May 14, 2008 | Panasonic KX-TGA560 Cordless Expansion...
Phone rings, but the caller can not hear us when we answer. I changed Batteries but it still does it. Phone is only 2 years old
it possible there is something like food or water or some solution has gone in the mic. ,
you could try cleaing the same with a old toothbrush, but it should be clean and dry.
also please see if its a particular caller or all of them, if particluar caller its possible for that caller having a problem , also possible for a call sometime this also happens that the voice doesnt go thru due to telephone exchange problems.
hope the solution helps !!
have a nice day !!
Apr 18, 2008 | Panasonic KX-TG5431 Cordless Phone
H300 Headset prob answering calls
yeah hold both the buttons on the side of your motorolaa h300 for 10 seconds let go for 5 seconds and hold your call button on you headset for another 5 seconds let your h300 light flash .....and then repeat your call................your welcome
Dec 07, 2007 | Motorola Mobility H300 Wireless Headset
User manual of GE 29878GE1 Digital Answering Machine
From the Manual: RECORDING THE GREETING Before using your new answerer, you should record a greeting (the announcement callers hear when your answering system answers a call). If you don't record a greeting, callers hear a default greeting which says, "Record message after tone." When recording the greeting you should be about 6 inches from the unit. Eliminate as much background noise as possible. 1. Prepare your greeting. Sample Greeting: Hi, this is (use your name here). I can?t answer the phone right now, so please leave your name, number, and a brief message after the tone, and I?ll get back to you. Thanks. 2.Hold down the GREETING button. After the tone, you have 30 seconds to record your greeting. 3.Release the GREETING button when you finish. The greeting will playback automatically. NOTE: Your recording time should not be less than 2 seconds. Otherwise the unit will return to the default greeting.
Jun 05, 2007 | GE 29878GE1 Digital Answering Machine
For incoming calls, the caller cannot hear me for 2-10 seconds after I pick up
You've got an IP issue somewhere in your setup. It sounds like the call is being lost and then the phone is querying the DNS server to find out where it should be looking for the call. Do you have a VOIP server name or it's IP address in the setup? Are you using DHCP or manually assigning IP addresses? If the VOIP server is not on a static IP, I would fix that first. Post back here the answers and we can look at it further.
Aug 04, 2006 | Polycom SoundPoint IP 501 IP Phone
Panasonic KX-T7730 Corded Phone Logo
91 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
