Question about HP Officejet J5780 All-In-One InkJet Printer
Paper keeps jamming. I think there is a small peice of paper left in. How do I get inside it to renove any debris ?
  • rayandcindy Jun 26, 2009
    Thanks. The printer did not come with an instruction book. In the meantime I printed one out from some site and there was the (your) solution.
    Many thanks
    President:
  • 3,085 Answers
There is an access door at the rear bottom of your printer.
Posted on Jun 26, 2009
PAPER KEEPS JAMMING WHEN TRYING TO PRINT
Sometimes there is either a peice of paper left from tue first jam, or like i found in my daughters, S printers dried raisin blocking the paper, so make sure NOTHING is in the way inside the printer, if you have to turn it upside down and shake it to see if you hear something rateling in it
Jul 21, 2011 | HP J4680 Office Jet All-In-One Printer
I am receiving a message, "paper jam", yet there is none. At the same time, It goes to sleep. How do I get it to awaken? Any assistance is appreciated.
LOL, I know it isn't funny but it sounded funny. There is probably a small particle of paper stuck inside it, and that little peice of paper is telling the machine to sleep until the paper is removed. Try spraying some keyboard cleaner where the paper goes in and where the paper goes out.
Aug 06, 2010 | Brother IntelliFax-2820 Laser Fax
Printer takes in paper then fails to print and reports a jam.
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | HP Photosmart 7450 InkJet Printer
Keep saying paper jam
Hi Mesha
Jan 24, 2010 | Brother MFC-3240C All-In-One InkJet...
My Lexmark 4350 printer keeps saying that there is a paper jam when there is not, can this be easely fixed!
check for any small peices of paper that may have been left behind from a previous jam even a very small peice in the right place can cause this
Jan 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
The orange down arrow light keeps blinking. what's wrong?
This means that either the printer is out of paper or there is a paper jam.
Try to check all feeds for a paper jam. Once the jam is cleared your printer should resume printing again.
Sometimes even a small peice of paper can cause the printer jam
Oct 03, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Mar 17, 2009 | Canon D320 imageCLASS Digital Copier
I have a HP OFficjet 7210 All-in-one that keeps jamming.
Clean the pickup rollers and ensure that there isn't a small peice of paper lodged between them. I use a product called "rubber renew", it removes the dust, dirt, etc. and eats away someof the rubber to make it rough again.
Nov 18, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
