Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool estate, is no longer cold, for the freezer or icebox
  • 417 Answers
pull it out and study the back of the fridge down where the cardboard cover is, ((careful of the water line)) sometimes the cardboard cover will come loose and get in the way of the small fan back there, if it does , it will do that, if thats not it, probably your best bet will be to call and have a guy come out and test it. craigslist has cheap side by side fridges, since theyre such a pain to replace..
good luck
J
Posted on Jun 26, 2009
Icebox Not cold
What is the model number?
Oct 27, 2012 | Frigidaire Refrigerators
The ice and the cold water have a musty odor
Check if any food may have fallen inside the icebox, like frozen meat. You can also install a filter between the ice maker and the water supply to see if it solves the problem. Good luck!
Aug 04, 2011 | Whirlpool Refrigerators
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Kenmore Refrigerators
My Estate by Whirlpool freezer coils freeze up and both the freezer and lower compartments won't stay cold. I can manually thaw the freezer and it works ok for a few days then does it again
You have a problem with the automatic defrost cycle, it is typically the defrost control, which is located in the compartment next to the thermostat or cold control. If you send me your entire model number from the tag on the inside I can get you the part number needed.
Jun 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Whirlpool Estate series fridge/bottom freezer no longer gets cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Whirlpool ET0MSRXTL00 top freezer that no longer stays cold
Hi, Is there a frost buid up or is the evaporator fan motor running? Let me know andI can help you further.
Vic
May 16, 2009 | Whirlpool ET0WSRXML Top Freezer...
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Ariston fridge freezer - drips water
I'm afraid if the door isn't sealing properly and staying cold then the ice will always be melting somewhat and dripping. Is there ANY way to glue/epoxy/fiberglass that part back on or repair the door, etc.? If you can't get repair parts either you may be stuck with a broken cooler. It seems like some shop (boat shop, auto bodyshop, etc.) should be able to repair those items with fiberglass or something. I guess it just depends on the cost to repair verses to buy new again.
Jan 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
Washing Machines Logo
61 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
