Question about Maytag MSD2454G Side by Side Refrigerator
Does baby powder help the door from sticking?
Does baby powder help the door from sticking on my fridge?
  • 417 Answers
the seal should stick to some degree anyways, its magnetic, but you can try a little wd-40 on there if its something sticky for sure..
J
Posted on Jun 26, 2009
Have maggots pouring from fridge, all over floor. Sprayed & swept for hours but maggots still everywhere. How do I kill them
CLOREX or any chlorine application. Apply full strength inside the box and under the machine as well. Open door and allow to air dry. Get Baking Powder made for refrigerators and let it absorb the chlorine smell. Replace with new baking powder boxes one the fridge is turned back on.
Jan 31, 2018 | Refrigerators
Does baby powder cause ovarian cancer
Here is a pretty informative article that covers the generals. You should be able to get all the info you need along with links to other articles.
http://www.webmd.com/ovarian-cancer/news/20000411/talc-powder-ovarian-cancer-link
Feb 15, 2015 | Johnson & Johnson Johnson's Baby Powder,...
I got a small grease spot on a silk dress - what is the best way to remove it
If you haven't washed it yet, lay the dress flat and pour baby powder, not corn starch, but real baby powder on the grease spot and let sit overnight or a day or two if necessary. When you shake powder off the dress and launder normally the grease should be gone. Air dry to make sure the grease is gone before drying normally. Baby powder works miracles on grease! Good Luck!
Aug 27, 2011 | Clothing Accessories
There is a bad odor coming out of the fridge when you open the door, everything else works fine.
Is it a food odor or metallic? Try crushing up some charcoal into a powder and place in the fridge in an open dish.
Feb 23, 2011 | Refrigerators
What is used to maintain weather stripping and door hinges
for weather stripping on your vehicle, if it is being stored use baby powder and work it in. If its being used regulary there are some great products out there 303, Vinylex, 3M Rubber Dressing, Wurths, etc.
As for the door hinges. A white lithium grease should work great.
Thank you,
Lee
Oct 01, 2010 | 2006 Ford F-150
Changing a door seal how do you replace the door seal ?
  1. Check the door seal size. Measure your door or doors, and take down the make and model number. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+9665908481+9016233241+8388126455+8941458308+8509902424+8509902424+9683278076+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Order a replacement door seal. It's easy to find them online. Make sure to check the model number for your refrigerator when you order it. When it arrives, hold the new door seal up against the old door seal to compare the size. The sizes are rarely incorrect, but it will save you the trouble of doing the job twice if you happened to receive the wrong door seal.
  3. 3Locate the screws. Lift the edges of the seal and find the screws underneath that are holding in the plastic liner and door seal. Often, the screws hold in a plastic liner, which in turn clamps the door seal to the door.
  4. 4Loosen the screws. Begin to loosen the screws that hold in the door seal. DO NOT take the screws all of the way out. It is unnecessary and will create more of a job for you. If at all possible, loosen only a few screws at a time, as you go.
  5. 5Remove the old seal. Once all of the screws are loose, the door seal should easily slide out from behind the plastic liner. Don't be too forceful when doing this step, since some plastic liners can be quite brittle and crumble if you are too rough. If the plastic is old, replace it.
  6. 6Insert the new seal. Begin slipping the small lip of the new door seal behind the plastic liner of the fridge. The best method is to start in the top corners and work your way around the door.
  7. 7Tighten the screws. Once the door seal is in a certain section, you can begin tightening the screws. Begin with the 8 corner screws, and then check the alignment of the door while closed. Also check that the seal is even and straight. If the door is twisted, you can easily manipulate the door to twist back into shape whilst the screws are loose. Then tighten the remaining screws.
  8. 8Apply powder. Use a bit of baby powder or talcum powder to prevent sticking. Rub some powder around the hinge side corners of the door seal, and where the seal slides. This will help to prevent the door seal from twisting as it meets the metal of the fridge. If this still doesn't prevent twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour.
  9. 9Check for gaps. Look for any gaps in the door seal, especially at the top on the opening side. These can form due to the door dropping or being out of alignment. One way to check is to turn on a flashlight and place it inside, then close the door and look for light.
  10. 10Fix any gaps in the door seal. Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
  11. 11Check the corners. If the application of powder hasn't prevented the door seal twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour. The door seal will then have enough time to mould into the correct shape.
Aug 29, 2010 | Refrigerators
Why does my acelerator stick when i stop
Do you have a stop on it that stops it from coming up? Is that where it is sticking? Mine used to stick up there and drive me nuts, go to step on the gas and nothing, I put a little baby powder on it and it worked fine. Check it out.
Mar 19, 2010 | 1987 Peugeot Liberte
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Jun 21, 2007 | Westinghouse 24 in. MDP531 RF...
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Maytag MSD2454G Side by Side Refrigerator Logo
371 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
