Question about Samsung HL-P5063W 50" Rear Projection HDTV
Problem with the White vertical lines on Samsung 50 in DLP
Looks like I have the same issue as another person with the Samsung HL-P5603W DLP TV, with vertical White Lines running up and down the screen. I believe the fix is to replace the DMD Board assembly. Does that hold true? Over 500 bucks just for the part. Is there anybody out there fixing these for much cheaper than that?
Re: Problem with the White vertical lines on Samsung 50...
We purchased the Samsung HLP6163WX/XAA (61" dlp tv) in early 2005. Since then, we've replace under warranty a power board, and then out of warranty a bulb, and just this month 12-2011, I purchased a DMD board, which purportedly will take care of the sets of black vertical fine lines that look like guitar strings. I paid $99 for the board, and $15 shipping from a parts supplier in San Francisco. Ebay supplier advertised as "new", not refurb'd or used. Hopfully this will fix it.
Posted on Dec 28, 2011
  • 1,694 Answers
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Posted on Nov 07, 2007
0 characters
3 Points
I have green vertical squiggles lines over whole screen
possibly the DMD chip goes bad, you can try to disassemble your tv, and take out the DMD chip, when carefully inspect its mirror, whether you found any lines or white pots in it.
if it had lines or white pots, you have to replace it.
Oct 26, 2014 | Samsung HL-S5087W DLP TV
My tv have vertcal lines wend I just tern on but wend heat up dosent do any more ?? Samsung HL-R5656W 56 in. HDTV DLP TV
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
Apr 03, 2010 | Samsung HL-R5656W 56" DLP HDTV
try reseating the dvi cable inside the set
Jun 13, 2009 | Samsung HL-S5087W DLP TV
Color disappears from DLP display
the problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Apr 23, 2009 | Samsung HL-S5087W DLP TV
Numerous white spots on Smasung DLP TV
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
600 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
