Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Engine starving for fuel, fuel filter very low, almost empty
Craftsman riding lawnmower, briggs and stratton 24hp v twin. fuel tank under the seat. has fuel pump above one of the valve covers,( how does that work?). replaced fuel filter but it still starves for fuel. Surges and cuts out once in a while under a load.
Any help with this would be a great .
Thank-You
    Problem Solver:
  • 19 Answers
Your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Posted on Mar 14, 2010
    President:
  • 1,723 Answers
Did you bring the mower from another area? Could need jetting for your altitude.
Posted on Jun 30, 2009
No doubt high elevation Colorado residents did re jet their cars to use LEANER jets due to less oxygen in the air, i.e. thin air.
I plan to plumb in an outboard fuel primer bulb to pump when ever the engine stalls / starves,until we can make a more informed decison.
Posted on May 06, 2010
Where is the fuel pump on the Briggs & Stratton engine on this mower? Thanks
unless its a briggs I/C engine(orange) or a vanguard V twin (these use a vacuum driven pump) it doesn't have a fuel pump all it has is an inline fuel filter the fuel tank is just slightly higher than carb (gravity) , now it does take a special type of fuel filter (gravity type) and just any filter will not work , id use the factory replacement filter , briggs sells em lots of places
Oct 27, 2015 | Briggs & Stratton Garden
24 hp briggs intek starving for fuel
Always check for jet. 90 percent of the time it is clogged. Remove the bowl and float and it is the center screw.
Jun 10, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 23 hp Briggs Vanguard that i have to run with the choke a quarter of the way on or it will die. What will cause this to happen?
It is starving for fuel. Replace the fuel filter first thing. Clean or replace the air filter. Also purchase a can of Seafoam or Techron fuel treatment. Follow the directions on the can and put some in a full tank of fuel. After running this full tank if you still have the problem then you may need the carburetor adjusted or cleaned out. I would advise you to seek professional help in accomplishing this.
Aug 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
2,924 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
