Question about LG WD-3274RHD Front Load Washer / Dryer
How do we clean the dryer 's filter?
I have cleaned the washer's filter. But the inside of the machine has a residue of fibres which are left after dryer's cycles.
I think I know what you mean - the machine itself does not have a lint filter and over time I've noted that it can build up around the large rubber door gasket. You will simply need to be more fastidious about cleaning it out after each cycle. I've had success using an old toothbrush dunked in some water to get the stuff out. The washer's filter (located in the lower left corner of the machine) only traps large solid debris. Hope that helps!
Posted on Feb 02, 2010
The washer for our Maytag LS7806 has quit, but the dryer still works. A few weeks after we stopped using the washer, it started to smell of rotten eggs. I can't find a filter to clean, any ideas?
The bacteria in the washer part are causing the smell.
Give the inside a good wipe round with a damp cloth to remove any visible residue.
Leave the door and soap drawer fully open so that the inside dries out after a couple of days; that should fix it.
Jan 06, 2018 | Maytag Washing Machines
Indesit IDL 850 dishwasher: dishes in the top drawer ONLY are dirty: residues is left on and inside what is in the top drawer, so that they come out dirtier than when they went in. This is new: I have not...
If he Dishes Are Not Clean:
- Have you put the right amount of detergent into the dispenser?
- Is the wash cycle suitable for the dishes you have placed inside the
appliance?
- Are the filter and microfilter clean?
- Can the sprayer arms turn freely?
This is how the manual helps.
Jun 29, 2017 | Indesit Dishwashers
My legacey washer is leaving lint on clothes
Of course you've probably already done this but if not, check the filter and clean it. Additionally, you might need to wash it to remove residue from dryer sheets and BE SURE TO DRY IT BEFORE PUTTING IT BACK IN THE DRYER. If the filter is clean and washed and you're still having lint, get a dryer brush and clean down in the area where the filter goes. Also go to the vent area outdoors and clean that with the dryer brush. That area can become clogged over time and prevent the dryer from effectively removing the lint. Furthermore, check the exhaust piping. If it is bent, gently move it a little to dislodge any lint that might have gotten stuck there over the years.
Nov 04, 2010 | Maytag Washing Machines
I have a sour smell coming from my washer that does not seem to go away, what is the problem? I have seen many other postings on the internet about their having this problem, seems to be the washer.
After the odor has been removed washing habits need to change so it doesn't return. Washing machine odor is caused by
1. Overuse of detergent. Use no more than 1 tbsp of whatever detergent is used (unless washing soiled clothing).
2. Using fabric softener because it's dispensed in the rinse cycle. Dryer sheets or dryer balls are better options. Dryer sheets can also be overused and coat the inside of the dryer with siliconized chemicals that cause clothing to retain odors. Sensors inside the dryer can also be affected. The sheets can be torn in half or thirds
3. Using mainly cold water for washing is fine but makes preventive maintenance important. A hot wash or soak as your last cycle on wash day will help to dissolve residue.
4. Many front loading washer have a filter/trap that will catch debris. A partially clogged filter/trap can cause draining problems and odor. Save money on appliance repair by cleaning it yourself. Consult your owner's manual for instruction.
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
A dark residue inside of dryer
Sounds like an ink pen was left in the clothing during wash and leaked out when put in the dryer
Oct 21, 2007 | Maytag HYE3658AY Electric Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
LG WD-3274RHD Front Load Washer / Dryer Logo
193 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
